This Arducam stereo camera bundle kit consists of two synched OV9281 global shutter cameras and an Arducam Camarray stereo camera HAT. As a stereo bundle system, it enables simultaneously working dual cameras with a variable baseline for better prototyping and evaluation with a single MIPI CSI camera slot: The two image sensors are on separated camera boards, and you easily move them around for different perspectives while the Camarray HAT handles the rest of the work. This is helpful for proof-of-concept stages when you may want more flexibilities than what a fixed stereo camera module can offer. You will be able to find the optimal baseline for your application with this bundle, and we welcome you to send us product customization requests after that.
What is Camarray
NOTE
Common Specs
Image sensor
Sensor Model | OV9281 |
Active Pixels | 1280*2×800 |
Resolution | 1MP*2 |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Lens Mount | M12 Lens |
Board
HAT Size | 65×56 mm |
Camera Board Size | 40×40 mm |
HAT Mechanical Drawing
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Camera HAT Connector Interface | MIPI CSI-2 22-pin 2-lane |
Camera Module Connector Interface | MIPI CSI-2 22-pin 2-lane |
Ribbon Cable Length | 150mm (22-pin), 300mm(15-22pin), 73mm(15-22pin) |
Pin # | Name | Description |
1 | GND | Ground |
4 | GND | Ground |
7 | GND | Ground |
10 | GND | Ground |
11 | CAM_D2_N | MIPI Data Lane 2 Negative |
12 | CAM_D2_P | MIPI Data Lane 2 Positive |
13 | GND | Ground |
14 | CAM_D3_N | MIPI Data Lane 3 Negative |
15 | CAM_D3_P | MIPI Data Lane 3 Positive |
16 | GND | Ground |
17 | CAM_IO0 | Power Enable |
18 | CAM_IO1 | LED Indicator |
19 | GND | Ground |
20 | CAM_SCL | I2C SCL |
21 | CAM_SDA | I2C SDA |
22 | CAM_3V3 | 3.3V Power Output |
Frame Rates | [email protected]*4 × 800(on RPi) [email protected]*4 × 800(on Jetson) |
Quick Start Guide
Hardware Setup
Driver Installation
1. Driver note
- Official driver
- Arducam MIPI camera driver
- Arducam V4L2 driver
1)Arducam MIPI camera driver is not in conflict with the official driver.
2)Arducam V4L2 driver is in conflict with the official driver. If you want to use the official driver, you need to uninstall the Arducam V4L2 driver first.
3)Arducam V4L2 driver is in conflict with Arducam MIPI camera driver. If you want to use the Arducam MIPI camera driver, you need to uninstall the Arducam V4L2 driver first.
4)Arducam V4L2 driver automatically overwrites the other two drivers. After uninstalling the Arducam V4L2 driver, it automatically reverts to the official driver.
2.Check the driver
Check if the system is installed with the Arducam V4L2 driver.
sudo nano /boot/config.txt
Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
1)If you see “dtoverlay=arducam”, the Arducam V4L2 driver has been previously installed and is in a valid state.
2)If you see “#dtoverlay=arducam”, it means you have installed Arducam V4L2 driver before, but it is uninstalled now, remove the “#” to restore the V4L2 driver. Then reboot Pi to take effect.
3)If you don’t see “dtoverlay=arducam” or “#dtoverlay=arducam”, it means that Arducam’s V4L2 driver has never been installed before, so you need to follow the instructions below for a complete installation.
3. Install the driver
#Download driver package
#Extract the archive files
tar zxvf Release.tar.gz
#Enter the extracted folder
cd Release/
#Install the driver
./install_driver.sh
#Reboot the device
Press y
, and then hit Enter
to reboot.
Get an error?
If your operating system is not released by official Raspberry Pi, the driver installation will report an error and give a version error message.
Check out Raspberry Pi official supported operating system:
4. Uninstall the driver
Note that the driver will occupy CSI hardware resources. After installation, you will not be able to use the raspistill tool. There are two ways to uninstall Arducam V4L2 driver:
cd Release/
./uninstall_driver.sh
NOTE
You have to reboot your Pi to make it effect.
Method 2: Modify configuration files
1.Type the following command:
2.Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
Modify “dtoverlay=arducam” as “#dtoverlay=arducam” to uninstall the V4L2 driver. Press 【Ctrl+X】, 【Y】,【Enter】to save the change and exit.
NOTE
First Use
1.Check whether the camera is detected
ls /dev/video0
2.List the available video modes
v4l2-ctl --list-formats-ext
At present, only “GREY” and “Y10P” formats are supported, and “Y10” format is not supported.
Run the command without results?
You might have to check the ribbon connection or install the drivers correctly, then reboot the Raspberry Pi.
3.Preview the camera feed in real time
#RAW10
arducamstill -t 0 -pixfmt Y10P -w 2560 -h 800
#RAW8
arducamstill -t 0 -pixfmt GREY -w 2560 -h 800
The last line shows frame in real time.
GREY for RAW8 and Y10P for RAW10.
-w and -h indicate the width and height of the input image.
Press Ctrl+C to exit the preview.
4.Save an image
Take a picture after a two-second (time in milliseconds) delay and save it as image.jpg.
arducamstill -t 1000 -o image.jpg -pixfmt GREY -w 2560 -h 800 -p 800,100,1024,768
5.Receive data without displaying the image
#RAW8
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='Y10P' --stream-mmap --stream-count=-1 -d /dev/video0
6.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
7. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=12
8.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 30. First, open two terminals, type the following command in the first terminal:
v4l2-ctl -c frame_rate=30
v4l2-ctl -l
IMPOORTANT NOTE
For example, if the frame rate is set to 80 fps, the display only goes up to 58fps.
But when you use only receiving data without displaying the image, the frame rate goes back to 80fps. (The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.)
Display Images via VLC Media Player
You can display images in real time via the VLC media player.
(The VLC player can only play images that are output in RAW8 format.)
1.Open VLC media plyer
2.Select 【Media】→【Open Capture Device…】
3.【Video device name】→ select “/dev/video0“→ click 【Play】
The image screen may be too large for the display to be complete.
Right-click on the VLC title bar and select 【Maximize】.
4.Adjust the exposure, gain, and frame rate
【Tool】→【Effects and Filters】
Drag the different slider to adjust the corresponding parameter.
Display Images via Mplayer
1.Install mplayer
sudo apt-get install mplayer
2.Display images
The image screen may be too large for the display to be complete.You need to drag the title bar to move the window to see the full image.
Right-click on the mplayer title bar and select 【Maximize】. Then you can see see the full image. (The image is pretty smooth.)
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 400
What’s Next
Application Note
Depth Mapping on Raspberry Pi
1.Install Driver
Please refer to this page for a driver demonstration.
2.Hardware Setup
3.Reboot RPi
After rebooting RPi, use ls /dev/video* command to see the video device.
4.Software Setup
4.1Download the demo code
git clone https://github.com/ArduCAM/3d-camera.git
cd 3d-camera/stereo-camera/RaspberryPi/stereo_depth_demo/
4.2 Install Dependency for Python3.X
Latest Raspbian version is recommended.
sudo apt-get update && sudo apt-get install -y libhdf5-dev libhdf5-serial-dev libatlas-base-dev libjasper-dev libqtgui4 libqt4-test && sudo pip3 install opencv-python==3.4.6.27
sudo pip3 install stereovision
sudo pip3 install matplotlib
5.Run the Programs
5.1Capture Images
python 1_test.py
Help message:
Example:
5.2 Collect Images for Calibration
python 2_chess_cycle.py
5.3 Separate Captured Images
python 3_pairs_cut.py
5.4 Calibration
python 4_calibration.py
5.5 Depth Map Tuning
python 5_dm_tune.py
5.6 Real-Time Depth Map Using Video
python 6_dm_video.py
Using on OpenCV
Make sure you have installed the driver.
Download the file here.
import numpy as np import cv2 import time def fourcc(a, b, c, d): return ord(a) | (ord(b) << 8) | (ord(c) << 16) | (ord(d) << 24) def pixelformat(string): if len(string) != 3 and len(string) != 4: msg = "{} is not a pixel format".format(string) raise argparse.ArgumentTypeError(msg) if len(string) == 3: return fourcc(string[0], string[1], string[2], ' ') else: return fourcc(string[0], string[1], string[2], string[3]) cap = cv2.VideoCapture(0,cv2.CAP_V4L2) cap.set(cv2.CAP_PROP_FOURCC, pixelformat("GREY")) cap.set(cv2.CAP_PROP_CONVERT_RGB,0) now = time.time() frame_num=0 while(True): if time.time() - now > 1: now = time.time() print(frame_num) frame_num=0 else: frame_num = frame_num+1 # Capture frame-by-frame ret, frame = cap.read() # Display the resulting frame cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break # When everything done, release the capture cap.release() cv2.destroyAllWindows()
Then type the following command:
sudo python ov9281_dulcam_opencv_raw8.py
