This Arducam 5MP Synchronized Stereo Camera Bundle Kit is capable of running two 5MP OV5647 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Raspberry Pi. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. You can use this bundle to build your stereo camera system for depth-related vision applications or advanced surveillance cameras.
What is Camarray
NOTE
Common Specs
Image sensor
Sensor Model | OV5647 |
Active Pixels | 2592×1944 |
Resolution | 5MP |
Pixel Size | 1.4μm×1.4μm |
Lens Assembly
Interchangeability | No |
Focus Distance | 1m to infinity |
Focus Type | Fixed Focus |
Field of View(FoV) | 54°H x 41°V |
Board
HAT Size | 65×56 mm |
Camera Board Mechanical Drawing
HAT Mechanical Drawing
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Ribbon Cable Length | 80mm(22-pin), 73mm(15-22pin) |
Pin # | Name | Description |
1 | GND | Ground |
4 | GND | Ground |
7 | GND | Ground |
10 | GND | Ground |
11 | CAM_IO0 | Power Enable |
12 | CAM_IO1 | LED Indicator |
13 | CAM_SCL | I2C SCL |
14 | CAM_SDA | I2C SDA |
15 | CAM_3V3 | 3.3V Power Input |
Driver Performance
Max video resolution | 1080p |
Quick Start Guide
Hardware Setup
Check the Driver
- Official driver
- Arducam MIPI camera driver
- Arducam V4L2 driver
1)The MIPI camera driver does not conflict with the official driver. But the V4L2 driver conflicts with the official driver and MIPI camera driver.
2)Installing the Arducam V4L2 driver will automatically overwrite the other two drivers. After uninstalling the Arducam V4L2 driver, it will automatically revert to the official driver.
3)If you want to use the official commands like raspistill and raspivid, you need to check if the V4L2 driver is installed first, if so, uninstall it.
Arducam 5MP Synchronized Stereo Camera uses the official driver or MIPI camera driver.
Check if the V4L2 driver is installed:
1.Type the following command:
sudo nano /boot/config.txt
2.Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
1)If you see “dtoverlay=arducam”, modify it as “#dtoverlay=arducam” to uninstall the V4L2 driver. Press 【Ctrl+X】, 【Y】,【Enter】to save the change and exit. Finally, type the following command to reboot.
sudo reboot
2)If you don’t see “dtoverlay=arducam”, it means you haven’t installed the V4L2 driver. Please follow the below steps to continue.
3)If you see “#dtoverlay=arducam”, it means that Arducam’s V4L2 driver has been installed before, but it is uninstalled. Please follow the below steps to continue.
Check the Camera
1.Go to the main menu and open the Raspberry Pi Configuration tool.
2.Select the Interfaces tab and ensure that the camera is enabled:
3.Reboot your Pi
4.Check whether the camera is detected
- vcgencmd get_camera
- detected=1 means the camera is detected. (The camera is OV5647, IMX219, or IMX477.)
- detected=0 means the camera is not detected. You might have to check the ribbon connection correctly, then reboot the Raspberry Pi.
First Use with Official Driver
You can refer to the page for instructions. Or refer to this page for the official commands.
NOTE
The images from two cameras are compressed to half of the original in the horizontal direction, but the field of view remains the same and the composite output image has the same resolution as the input. The Raspberry Pi does not know that it is a synthesized image and still receives it as a normal image to display.
1. Preview the camera feed in real time
Execute the official native command raspistill
raspistill -t 0
Press 【Ctrl】+【C】 to exit the preview.
Execute the official native command raspivid
raspivid -t 0
It can be zoomed into the display.
raspistill -t 0 -p 800,100,1024,768
raspivid -t 0 -p 800,100,1024,768
800,100 indicates the starting position of the window (top left corner).
1024,768 indicates the size of the image after scaling.
2. Save an image
Take a picture after a two-second (time in milliseconds) delay and save it as image.jpg.
Take a custom sized photo
raspistill -t 2000 -o image.jpg -w 1920 -h 1080
3. Save a video
Record 10 seconds (time in milliseconds) of h264 video and save it as video.h264.
raspivid -t 10000 -o video.h264
Double click “video.h264” file, it will call the VLC media player to play.
4. Advanced controls
The stereo camera HAT support channel selection and digital pan. It requires to write onboard ArduChip registers through the I2C bus on Raspberry Pi. So the user needs to active the I2C bus first(please refer to chapter 5.1 or the following methods).
Clone the GitHub repository from https://github.com/ArduCAM/MIPI_Camera.git
and run the script ./enable_i2c_vc.sh
, a reboot is required.
For more information about the ArduChip registers, please refer to chapter 7.
Before issuing any control command, you have to launch preview or video using raspistill or raspivid command first, then launch another terminal window to run the following commands.
4.1 Switch to CAM0, Single Mode
Run command i2cset -y 0 0x24 0x24 0x01
to switch from stereo mode to single mode CAM0 feed.
4.2 Switch to CAM1, Single Mode
Run command i2cset -y 0 0x24 0x24 0x02
to switch from stereo mode to single mode CAM1 feed.
4.3 Swtich back to Stereo Mode, Resized Full-Combine
Run command i2cset -y 0 0x24 0x24 0x00
to switch back to stereo mode.
First Use with Arducam MIPI Camera Diver
1.Download and Install the SDK
Download the SDK library:
Enter the SDK directory:
cd MIPI_Camera/RPI/
Install SDK:
make install
Enable I2C_0:
chmod +x enable_i2c_vc.sh ./enable_i2c_vc.sh
Press 【y】, 【Enter】 to reboot Pi.
2.Compile demo
Enter the directory:
cd MIPI_Camera/RPI/
Compile demo:
make clean && make
1.It doesn’t matter if opencv reports an error
2.The demo program needs to be recompiled after modification.
3.Run demo (through the “arducamstill” command)
This is a comprehensive application, user can use it to preview, get images in a different format and fine tuning the image quality.
3.1 Get help
Execute the following command to get a description of the parameters of the arducamstill command.
Be sure to run it in the MIPI_Camera/RPI directory.
./arducamstill -?
3.2 Preview the camera feed in real time
Check the supported modes.
./list_format
You can only run the modes that include “Used for Arducam Synchronized stereo camera HAT” in the mode description.
Take mode12 for example:
./arducamstill -t 0 -m 12
4.NOTE
Arducam MIPI Camera Driver does not conflict with the official driver.
● If you have compiled the Arducam MIPI Camera demo before, after running the official commands (raspistill and raspivid), you can enter the Arducam MIPI Camera demo directory and run the Arducam MIPI Camera commands directly (no need to compile and reboot the system again).
● When you want to run the official commands (raspistill and raspivid) again after running the Arducam MIPI Camera command, you need to restart the system first.
What’s Next
- Check the Application Note for applications like Depth Mapping on Arducam Stereo Camera HAT with OpenCV.
