This Arducam stereo camera bundle kit consists of two synched OV9281 global shutter cameras and an Arducam Camarray stereo camera HAT. As a stereo bundle system, it enables simultaneously working dual cameras with a variable baseline for better prototyping and evaluation with a single MIPI CSI camera slot: The two image sensors are on separated camera boards, and you can easily move them around for different perspectives while the Camarray HAT handles the rest of the work. This is helpful for proof-of-concept stages when you may want more flexibility than what a fed stereo camera module can offer. You will be able to find the optimal baseline for your application with this bundle, and we welcome you to send us product customization requests after that.
What is Camarray
NOTE
Common Specs
Sensor Model | OV9281 |
Active Pixels | 1280*2×800 |
Resolution | 1MP*2 |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Lens Mount | M12 Lens |
Board
HAT Size | 65×56 mm |
Camera Board Size | 40×40 mm |
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Camera HAT Connector Interface | MIPI CSI-2 22-pin 2-lane |
Camera Module Connector Interface | MIPI CSI-2 22-pin 2-lane |
Ribbon Cable Length | 150mm (22-pin), 300mm(15-22pin), 73mm(15-22pin) |
Pin # | Name | Type | Description |
1 | GND | Ground | Power Ground |
2 | CAM_D0_N | Output | Pixel Data Lane0 Negative |
3 | CAM_D0_P | Output | Pixel Data Lane0 Positive |
4 | GND | Ground | Power Ground |
5 | CAM_D1_N | Output | Pixel Data Lane1 Negative |
6 | CAM_D1_P | Output | Pixel Data Lane1Positive |
7 | GND | Ground | Power Ground |
8 | CAM_CK_N | Output | Pixel Clock Output Form Sensor Negaitive |
9 | CAM_CK_P | Output | Pixel Clock Output Form Sensor Positive |
10 | GND | Ground | Power Ground |
11 | CAM_D2_N | Output | Pixel Data Lane2 Negative |
12 | CAM_D2_P | Output | Pixel Data Lane2 Positive |
13 | GND | Ground | Power Ground |
14 | CAM_D3_N | Output | Pixel Data Lane3 Negative |
15 | CAM_D3_P | Output | Pixel Data Lane3 Positive |
16 | GND | Ground | Power Ground |
17 | POWER-EN | Input | Power Enable |
18 | LED-EN | I/O | LED Enable/XCLK |
19 | GND | Ground | Power Ground |
20 | SCL | Input | SCCB serial interface clock input |
21 | SDA | I/O | SCCB serial interface data I/O |
22 | VCC | Power | 3.3V Power Supply |
Frame Rates | [email protected]*2 × 800(on RPi) [email protected]*2 × 800(on Jetson) |
Quick Start Guide
Hardware Setup
Driver Installation
1.Driver note
For the new version of the camera, we recommend this driver for Raspberry Pi:
Pivariety V4L2 driver
Raspberry Pi is transitioning from a legacy camera software stack based on proprietary Broadcom GPU code to an open-source stack based on libcamera. Raspberry Pi OS images from Bullseye onwards will contain only the libcamera-based stack. In order to connect the new system and libcamera, we developed the Pivariety V4L2 driver.
Pivariety V4L2 driver supports using libcamera and arducamstill to fetch images. Therefore, for some customers who still want to use Buster legacy system, we recommend using arducamstill, no need to install OBISP driver.
If you encounter any problem when using the camera, please directly contact [email protected] for help.
Note:
The camera you are using may be the previous version, which looks the same as the new version. If you encounter any problem when you are referring to the following steps, please follow the previous version driver.
2.Install the Driver
The Pivariety V4L2 kernel driver supports the latest version of Raspberry Pi OS. (January 28th,2022 or later releases, Debian version:11(Bullseye)).
Please make sure your Raspberry Pi OS is downloaded from these two official sources:
– Raspberry Pi Buster >
– Raspberry Pi Bullseye >
If you want to compile the kernel driver by yourself, please follow the chapter on How to build Raspberry Pi Kernel Driver-Pivariety Camera.
2.1. Installation
wget -O install_pivariety_pkgs.sh https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/install_script/install_pivariety_pkgs.sh chmod +x install_pivariety_pkgs.sh ./install_pivariety_pkgs.sh -p kernel_driver
You can also follow the step to install the driver by yourself
- Download V4L2 Pivariety driver
wget https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/Arducam_pivariety_v4l2_v1.0/arducam_pivariety_v4l2.tar.gz
- 1.2 Decompress V4L2 Pivariety driver
tar -zxvf arducam_pivariety_v4l2.tar.gz Release/
- 1.3 Install V4L2 Pivariety driver
cd Release/
./install_driver.sh
After pressing y to reboot, driver installation is complete.
Please make sure the camera is connected correctly before rebooting, otherwise, you will not detect the camera.
If you want to upgrade the version of Raspberry Pi(for example you want to upgrade your pi3 or Pi3B+ to pi4 ), please reinstall the driver. Each version of Raspberry Pi when you use needs to be installed V4L2 Pivariety driver once.
2.2. V4L2 Pivariety driver detection
You can not use the official code(vcgencmd get_camera) to detect the camera! Please follow our DOC to detect the camera!
2.2.1 View V4L2 Pivariety driver status
dmesg | grep arducam
The driver is installed successfully if output arducam-pivariety and the camera has been detected if output firmware version.
[ 31.835619] arducam_vddl: disabling
[ 31.835638] arducam_vdig: disabling
[ 31.835657] arducam_vana: disabling
does not mean your driver installation is failing, please skip it.
By the way, it means that the camera is not detected if the probe failed is displayed, please check the camera connection.
You can see the following video nodes When everything is normal.
ls /dev/video* -l
2.2.2 View device node information
v4l2-ctl --list-formats-ext
2.3. Failed to Install V4L2 Pivariety Driver
Please check the kernel version, we only provide the driver for the latest official kernel version image when this Pivariety camera is released.
If you want to compile the kernel driver by yourself, please please follow the chapter on How to build Raspberry Pi Kernel Driver-Pivariety Camera.
If you want to switch to the native camera please go here to uninstall the V4L2 Pivariety Driver.
2.4. What is the next?
If you encounter any trouble, please following the DOC to troubleshooting.
3. How to build Raspberry Pi Kernel Driver
We only provide the driver for the latest official kernel version image when the Pivariety camera is released. Please check the kernel version if the driver installation fails. You can choose to compile the kernel yourself if the kernel version used is not provided by us.
There are two compilation methods:
3.1. The first way-Build from the kernel source
Please refer to the official documentation to compile the kernel.
NOTE
The instructions are divided into native builds and cross-compilation.
After obtaining the Linux source code, add the Arducam driver and device tree code through the apply patch.
git clone https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver.git cd <path>/linux patch -p1 -i <path>/Arducam-Pivariety-V4L2-Driver/patchs/arducam_driver.patch
At this point, your kernel driver building is complete! You can go to the chapter on the next.
3.2. The second way-Build from the kernel headers
3.2.1 Download the kernel source code
cd ~ sudo apt update && sudo apt install git bc bison flex libssl-dev sudo wget https://raw.githubusercontent.com/RPi-Distro/rpi-source/master/rpi-source -O /usr/local/bin/rpi-source && sudo chmod +x /usr/local/bin/rpi-source && /usr/local/bin/rpi-source -q --tag-update mkdir $(uname -r) rpi-source -d $(uname -r)
3.2.2 Compile the driver and device tree
cd ~ git clone https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver.git cd Arducam-Pivariety-V4L2-Driver/src # compile dtbo patch -p1 -d /lib/modules/$(uname -r)/build -i $(pwd)/../patchs/arducam_device_tree.patch make -C /lib/modules/$(uname -r)/build dtbs sudo cp /lib/modules/$(uname -r)/build/arch/arm/boot/dts/overlays/arducam.dtbo /boot/overlays/arducam.dtbo # manully add dtoverlay=arducam in /boot/config.txt # manully add dtparam=i2c_vc=on in /boot/config.txt # compile arducam.ko make && sudo make install sudo depmod sudo modprobe arducam
What is the next?
If you encounter any trouble, please follow the DOC to troubleshooting.
How to access the camera by using command line, Python,OpenCV, and GStreamer
1. libcamera-dev and libcamera-apps Installation
wget -O install_pivariety_pkgs.sh https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/install_script/install_pivariety_pkgs.sh chmod +x install_pivariety_pkgs.sh ./install_pivariety_pkgs.sh -p libcamera_dev ./install_pivariety_pkgs.sh -p libcamera_apps
You can also be following the step to install the driver by yourself
1.1. Use pre-compiled binaries
Note: If you don’t want to compile, you can choose to use our pre-compiled deb package.
1.1.1 Install libcamera
wget https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/v0.0.2/libcamera-dev.deb -O libcamera-dev.deb
sudo apt install ./libcamera-dev.deb
1.1.2 Install libcamera-apps
wget https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/libcamera-apps-v0.0.2/libcamera-apps.deb -O libcamera-apps.deb
sudo apt install ./libcamera-apps.deb
If you use the pre-compiled package please go to the chapter of Select the correct graphics driver.
1.2. Build from the source code
1.2.1 Install dependency
If you need to use the plugin GStreamer, please install the GStreamer dependency before compiling libcamera.
sudo apt update
sudo apt install -y libboost-dev libgnutls28-dev openssl \
libtiff5-dev qtbase5-dev libqt5core5a libqt5gui5 \
libqt5widgets5 meson libegl1-mesa-dev cmake \
libboost-program-options-dev libdrm-dev \
libexif-dev libegl1-mesa-dev
sudo pip3 install pyyaml ply
sudo pip3 install --upgrade meson
Optional dependencies (for GStreamer plugin).
sudo apt update
sudo apt install -y libgstreamer1.0-dev \
libgstreamer-plugins-base1.0-dev
1.2.2 Download and compile libcamera
Please note that Pivariety can’t be supported by Raspistill, you need to download libcamera to make it work. You can follow the installation steps listed in the code library.
cd ~
git clone git://linuxtv.org/libcamera.git
cd libcamera
meson build
cd build
meson configure -Dpipelines=raspberrypi -Dtest=false
cd ..
ninja -C build
On some lower memory platforms (e.g. 1GB) there have been cases of ninja exhausting all the system memory and aborting (as it will attempt to use all the CPU cores). If this happens, please try replacing ninja -C build by ninja -C build -j 2 – this will restrict Ninja to only 2 cores.
After downloading and compiling libcamera, you need to replace the code ipa_rpi.so with.
cd ~
wget https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/ipa-v0.01/ipa_rpi.tar.xz
tar xvf ipa_rpi.tar.xz
cp ipa_rpi.so libcamera/build/src/ipa/raspberrypi/
cd libcamera && sudo ninja -C build install
1.2.3 Download and compile libepoxy
libcamera-apps requires libepoxy to be installed.
cd
git clone https://github.com/anholt/libepoxy.git
cd libepoxy
mkdir _build
cd _build
meson
ninja
sudo ninja install
1.2.4 Download and compile libcamera-apps
cd
git clone https://github.com/raspberrypi/libcamera-apps.git
cd libcamera-apps
mkdir build
cd build
cmake ..
make -j4
sudo make install
To check everything is working correctly, type ./libcamera-hello – you should see a preview window displayed for about 5 seconds.
Note for Pi 3 devices
As we saw previously, 1GB devices may need make -j2 instead of make -j4.Also, Pi 3s do not by default use the correct GL driver, so please ensure you have dtoverlay=vc4-fkms-v3d in the [all] (not in the [pi4]) section of your /boot/config.txt file.
1.2.5 Select the correct graphics driver
There are 3 different graphics drivers available on the Raspberry Pi: firmware, FKMS, and KMS.
The firmware graphics driver cannot be used with libcamera-apps. The Raspberry Pi 4 and 400 use the newer FKMS graphics driver by default: this is compatible with libcamera-apps.
For all other models of Raspberry Pi, you must select the FKMS driver by adding the following line to the /boot/config.txt file(Note: Please add it under the [all] tag ).
[all]
NOTE: If you want to modify the file of /boot/config.txt, you need to reboot your device after modifying.
Tips: How to add the /boot/config.txt under the [all] tag?
a. open the filesudo nano /boot/config.txt #Use the mouse to draw to the bottom #Add dtoverlay=vc4-fkms-v3d under the table of [all]
b. Press the ctrl+o after editing, and press enter to save your file
c. Press the Ctrl+x to exit the editor
You can refer to here to learn more.
2. Use libcamera to access the camera
2.1. Use libcamera-app to access the camera
2.1.1 Capture image
For example, preview for 5s and save the image named test.jpg.
Parameter explanation
-t 5000 means preview for 5 seconds
-o test.jpg means to take a picture after the preview is over and save it as test.jpg
2.1.2 Record video
For example, record a H.264 10s video with the frame size 1920W × 1080H.
libcamera-vid -t 10000 --width 1920 --height 1080 -o test.h264
-t 10000 means recording for 10 seconds.
–width 1920 means to set the width to 1920.
–height 1080 means to set the height to 1080.
-o means to output the encoded data stream to the test.h264 file.
Note: H.264 format only supports 1920×1080 and below resolution.
2.2. Create a virtual video node (Access by Python)
2.2.1 Install V4l2loopback
Download kernel source code
cd ~
Compile driver
cd ~
git clone https://github.com/umlaeute/v4l2loopback.git
cd v4l2loopback
make clean && make
sudo depmod -a
2.2.2 Use v4l2loopback
sudo modprobe v4l2loopback video_nr=3
cd ~/libcamera # Installation using deb does not need to be executed
export GST_PLUGIN_PATH=$(pwd)/build/src/gstreamer # Installation using deb does not need to be executed
gst-launch-1.0 libcamerasrc ! 'video/x-raw,width=1920,height=1080' ! videoconvert ! tee ! v4l2sink device=/dev/video3
Now you can use the video 3 node to access the camera. (vlc/OpenCV etc. )
Python OpenCV:
import cv2
cap = cv2.VideoCapture(3)
while True:
ret, frame = cap.read()
cv2.imshow("Arducam", frame)
key = cv2.waitKey(1)
if key == ord('q'):
break
2.3 Use GStreamer to access the camera
2.3.1 Plugin GStreamer installation
Install GStreamer
sudo apt update
sudo apt install -y gstreamer1.0-tools
Preview
gst-launch-1.0 libcamerasrc ! 'video/x-raw,width=1920,height=1080' ! videoconvert ! autovideosink
2.3.2 Streaming MJPEG
# server
libcamera-vid -t 0 --width 1920 --height 1080 --codec mjpeg -n -l -o tcp://0.0.0.0:5001
# client
gst-launch-1.0 -v tcpclientsrc host=xxx.xxx.xxx.xxx port=5001 ! decodebin ! fpsdisplaysink sync=false text-overlay=false
2.3.3 Streaming H.264
# server
libcamera-vid -t 0 --width 1920 --height 1080 --codec h264 -n -l -o tcp://0.0.0.0:5001
# client
Display Images via VLC Media Player
The Raspberry Pi system comes with a VLC madia player.
(The VLC player can only play images that are output in RAW8 format.)
1.Open VLC media plyer
2.Select 【Media】→【Open Capture Device…】
3.【Video device name】→ select “/dev/video0“→ click 【Play】
The image screen may be too large for the display to be complete.
Right-click on the VLC title bar and select 【Maximize】.
4.Adjust the exposure, gain, and frame rate
【Tool】→【Effects and Filters】
Drag the different slider to adjust the corresponding parameter.
Display Images via Mplayer
1. Install mplayer
sudo apt-get install mplayer
2. Display images
The image screen may be too large for the display to be complete. You need to drag the title bar to move the window to see the full image. (The image is pretty smooth.)
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 200
What’s Next
Application Note
Depth Mapping on Raspberry Pi
- Install Driver
Please refer to this page for a driver demonstration.
2. Hardware Setup
3. Reboot RPi
After rebooting RPi, use ls /dev/video* command to see the video device.
4. Software Setup
4.1Download the demo code
git clone https://github.com/ArduCAM/3d-camera.git
cd 3d-camera/stereo-camera/RaspberryPi/stereo_depth_demo/
4.2 Install Dependency for Python3.X
Latest Raspbian version is recommended.
sudo apt-get update && sudo apt-get install -y libhdf5-dev libhdf5-serial-dev libatlas-base-dev libjasper-dev libqtgui4 libqt4-test && sudo pip3 install opencv-python==3.4.6.27
sudo pip3 install stereovision
sudo pip3 install matplotlib
5. Run the Programs
5.1Capture Images
python 1_test.py
Help message:
Example:
5.2 Collect Images for Calibration
python 2_chess_cycle.py
You can see from the video above to see more about this.
30 stereoscopic photos will then be saved in /scenes
folder.
5.3 Separate Captured Images
python3 3_pairs_cut.py
5.4 Calibration
python 4_calibration.py
5.5 Depth Map Tuning
python3 5_dm_tune.py
Here is how this looks like:
5.6 Real-Time Depth Map Using Video
python3 6_dm_video.py
The result:
Using on OpenCV
Make sure you have installed the driver.
Download the file here.
import numpy as np import cv2 import time def fourcc(a, b, c, d): return ord(a) | (ord(b) << 8) | (ord(c) << 16) | (ord(d) << 24) def pixelformat(string): if len(string) != 3 and len(string) != 4: msg = "{} is not a pixel format".format(string) raise argparse.ArgumentTypeError(msg) if len(string) == 3: return fourcc(string[0], string[1], string[2], ' ') else: return fourcc(string[0], string[1], string[2], string[3]) cap = cv2.VideoCapture(0,cv2.CAP_V4L2) cap.set(cv2.CAP_PROP_FOURCC, pixelformat("GREY")) cap.set(cv2.CAP_PROP_CONVERT_RGB,0) now = time.time() frame_num=0 while(True): if time.time() - now > 1: now = time.time() print(frame_num) frame_num=0 else: frame_num = frame_num+1 # Capture frame-by-frame ret, frame = cap.read() # Display the resulting frame cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break # When everything done, release the capture cap.release() cv2.destroyAllWindows()
Then type the following command: Generic Highlighting sudo python ov9281_dulcam_opencv_raw8.py EnlighterJS Syntax Highlighter
