0. Introduction
The Arducam IMX477 12MP PTZ camera mainly consists of the following two systems:
- An Arducam IMX477 12MP Camera Module
- A driver-board-based PTZ controlling system for Pan-tilt servos and Lens motors (Zoom and Autofocus)
It comes in two models with different package items. The following table shows their differences.
Camera w/ Zoom Lens | PTZ Control System | Pan-Tilt Servos | Servo Mounting Platform | |
B016712MP | Included | Included | Prepare your own | Prepare your own |
B0167B12 | Included | Included | Included | Included |
This instruction is mainly about operating the pan-tilt-zoom on the Raspberry Pi. If you want to use it with the Jetson Nano, refer to the last chapter.
We recommend you to go through this quick start carefully. If you encounter any issues while using this product, contact us or post in our forum.
1. Hardware Assembly
1.1 Connect the camera module to RPi with Ribbon Cable
The camera module connects to the RPi with a ribbon cable.
- To connect to the standard RPi, such as Pi 4, use the included 15pin-22pin white ribbon cable.
- To connect to Pi Zero and Compute Module, use the included 22 pin-22pin cable on your own.
The ribbon cable establishes a connection to the RPi and camera module with the help of metal contacts.
- The ribbon cable comes with metal contacts on both ends, but different sides.
- The camera module comes with metal contacts on the camera connector, beside the lens mount
- The RPi also comes with metal contacts on its CSI camera connector, beside the HDMI connector
Therefore, to ensure we are connecting the components in the correct way, just make sure the metal contacts of the ribbon cable are touching those of the camera module and the RPi on both ends.
1.1.1 Cable connection to the camera module
We have already done it for you. You don’t need to connect.
1.1.2 Cable connection to the Raspberry Pi
- Locate the camera port (CSI). It’s between the HDMI and audio port of the Raspberry Pi board.
- Gently pull up on the edges of the connector’s plastic clip and avoid pulling it off.
- Insert the ribbon cable. Make sure the metal contacts are facing the HDMI connectors. Do not bend the flex cable, and make sure it’s firmly inserted.
- Push the plastic clip down. Do it while holding the flex cable still, until the connector’s clip is back in place.
1.2 Connect the servo motors
Connect the 3-pin plug of the servo motors to the two sockets of the driver controller board.
- The left socket is for the pan servo, and the right socket is for the tilt servo.
- Note the color of the 3-pin plug. It’s brown, red and yellow from left to right.
You can refer to Picture 1.2.
1.3 Connect the driver controller board jumpers
The jumpers of the driver controller board can be separated into 3 pairs, and they are mainly for two purposes: I2C control signals and power supplies.
- The 1st pair connects to external power, with Pin#1 being Servo VCC and Pin#2 GND.
- The 2nd pair connects to the RPi’s GPIO pins for power, with Pin#3 being 5V and Pin#4 GND.
- The 3rd pair also connects to the RPI’s GPIO pins for I2C, with Pin#5 being SCL and Pin#6 SDA.
You can refer to Picture 1.3.
Picture 1.3 : Driver controller board jumpers connection
Please note that In this illustrator, the different colors of the jumper wires are just to make it easier to distinguish them from each other. The order of those colors varies from item to item, so it may not match the one you’ve received. Therefore, instead of its color, you should rely on the position of the wire to correctly connect the jumpers.
1.4 Overview of all the hardware connections
After you finish the hardware assemble process, refer to Picture 1.4 to review the connections you’ve made.
2. Using the Arducam PTZ Camera Example
Arducam offers example codes for pan, tilt, zoom, and auto-focus the camera module. You can also modify the example code to better suit your applications.
2.1 Prerequisites
2.1.1 Enable I2C on the Raspberry Pi
As we mentioned above, the driver controller board need I2C as the control signal. Therefore, we have to enable the I2C on the Raspberry Pi first.
We will edit the config.txt
to enable the I2C on RPi.
- In your Terminal, type the following command then hit
Enter
sudo nano /boot/config.txt
Now we will edit the config.txt file.
- Use
to navigate to the bottom of the config.txt file, and - Add the following line to it as the picture shows.
dtparam=i2c_arm=on
Save the change and exit.
- Press
Ctrl+o
to save the changes, then hitEnter
- Press
Ctrl+x
to exit.
After you exit Nano, go back to the Terminal and reboot so the changes can take effect.
Enter
sudo reboot
2.1.2 Install python-opencv
Enter
2.2 Download and run the examples
Firstly, we will download the Arducam_OBISP_MIPI_Camera_Module library.
Enter
to download the library:
git clone https://github.com/ArduCAM/PTZ-Camera-Controller
Enter
to enter the target folder:
cd PTZ-Camera-Controller/PTZ_IMX477_Controller/pyCode
Enter
to run the demo:
python FocuserExample.py
Here are some tips for using the demo example:
- After you run the focuser example, you will see instructions in the terminal. Read through the instructions for how to operate with the keys.
- Press
R
to reset the lens before pressingEnter
to start autofocus.
