Cameras for Raspberry Pi
  3. Cameras for Raspberry Pi
  4. Native Raspberry Pi Cameras
  5. Lens Shading Calibration (Fix the Red Tint After Swapping Lens)
20
Before and after the calibration
What is the lens shading effect we are talking about?
Sometimes when you replace the stock lens of the Raspberry Pi V1 or V2 camera with an Arducam Lens, you will encounter a color issue where the outer side of the picture looks pink or magenta. That is a lens shading artifact, which is expected but can be solved.
It is expected because the default compensation is only valid for the stock lens of the Pi cameras, while different lens should have been compensated differently for their optical results. It can be solved because the file to alter the compensation – the lens shading table – can be overridden to match your own lens.
How should I tune the configuration file to match my lens?
Well, you don’t have to tune the compensation yourself because Arducam has already done the work for you. You just need to double check which Arducam lens you have on hand and know what the corresponding files you will be using.
Here is the matching relationship between the FoV, SKU, and Part number of the most used Arducam M12 lenses, and you will be referring to the FoV degree numbers in the first column for the target file. As for the CS lens, there is a single general config file.
HFoV on 1/4″Part NumberSKU
10M2016ZH01LN001
20M2508ZH02LN002
40M2506ZH04LN003
45M2504ZH05SLN011
55M25360H06LN004
56LS-27227U1462
60M25360H06SLN012
65M40320M06SLN015
70M27280M07SLN013
80M27210H08LN005
90M40210M09SLN014
100M40180H10LN006
120M25170H12 LN007
140M25156H14LN008
160M30171H16LN009
200M32076M20LN010
Arducam lens matching relationship
How to use the Arducam presets for lens shading calibration?
Arducam has provided two methods to compensate the lens shading effect. The first is precompiled raspistill tools, and the second is pre-configured lens shading tables to be recompiled in your raspistill.c code. If you want to apply the compensation with raspivid, refer to the second method.
1. Use the precompiled raspistill tool
1.1 Download the customized Raspistill Tool
Arducam has provided tools for M12 lenses and CS-Mount lenses, and you can get the files here, or you can clone the repository.
git clone https://github.com/ArduCAM/NativePiCamera.git
1.2 Copy the file to the Pi Directory
raspistill precompiled
Check the table of matching relationships above to find the target file in NativePiCamera/bin, then copy it to the Pi directory.
For example
If you are using Arducam M40210M09S (LN014), you can know from the table that its FoV on V1&V2 Pi cameras is 90 degrees. Therefore, you need to copy the raspistill_M12_90_lens to /home/pi path.
1.3 Enter the Pi Directory
cd /home/pi
1.4 Run the tool
Let’s assume that we are still using the last example with the M40210M09S (LN014) lens, you can run the following command for a preview.
./ raspistill_M12_90_lens –t 0
2. Override the lens shading table and recompile
2.1 Download the repository
The lens shading table is in the same repository as the above. You can skip it if you’ve already done this from the first method. The lens shading table is in the NativePiCamera/ls_table folder.
Now recompile the raspistill source code to correct the lens vignetting using the generated lens gain table data (ubuntu16 cross compilation)
2.2 Download userland source code
 git clone https://github.com/6by9/userland.git
2.3 Install cmake
 sudo apt-get install cmake
2.4 Rename and copy the lens table
lens table calibration native
​​Rename the ls_table_M12_xx.h to ls_table.h and copy the file to the /userland/host_applications/linux/apps/raspicam path
3
2.5 Change the Raspistill.c file
There are two ways to change the file. You can use our file or alter yours.
  • copy the RaspiStill.c file to your default folder
sudo cp RaspiStill.c ./userland/host_applications/linux/apps/raspicam/RaspiStill.c
2.5.2 Alter your RaspiStill.c file
Open the raspistill.c file add some changes to the code.
  • Before #include "interface/vcos/vcos.h", add
#include "user-vcsm.h"
4
  • Before } RASPISTILL_STATE; add:
int lens_shading;
5
  • After mmal_port_parameter_set(camera->control, &cam_config.hdr); }, add:
      MMAL_PARAMETER_LENS_SHADING_T ls = {{MMAL_PARAMETER_LENS_SHADING_OVERRIDE, sizeof(MMAL_PARAMETER_LENS_SHADING_T)}};
      void *grid;
      #include "ls_table.h"
      ls.enabled = MMAL_TRUE;
      ls.grid_cell_size = 64;
      ls.grid_width = ls.grid_stride = grid_width;
      ls.grid_height = grid_height;
      ls.ref_transform = ref_transform;
      state->lens_shading = vcsm_malloc(ls.grid_stride*ls.grid_height*4, "ls_grid");
      ls.mem_handle_table = vcsm_vc_hdl_from_hdl(state->lens_shading);
      grid = vcsm_lock(state->lens_shading);
      memcpy(grid, ls_grid, vcos_min(sizeof(ls_grid), ls.grid_stride*ls.grid_height*4));
      vcsm_unlock_hdl(state->lens_shading);
      status = mmal_port_parameter_set(camera->control, &ls.hdr);
      if (status != MMAL_SUCCESS)
         vcos_log_error("Failed to set lens shading parameters - %d", status);
6
2.6 Change the RaspiVid.c file
  • copy the RaspiVid.c file to your default folder
sudo cp RaspiVid.c ./userland/host_applications/linux/apps/raspicam/RaspiVid.c
2.6.2 Alter your RaspiVid.c file
Refer to 2.5.2 for the same steps.
2.7 Recompile
In your terminal, type the following command:
cd userland
./buildme
~/userland/build/arm-linux/release ~/userland
7
Then you will get the new raspistill tool which is in the build/bin/ path
8
The expected results of the Calibration
  • M12 FOV:10°
10
  • M12 FOV:20°
20
  • M12 FOV:40°
40
  • M12 FOV:45°
45
  • M12 FOV:55°
55
  • M12 FOV:60°
60
  • M12 FOV:65°
65
  • M12 FOV:70°
70
  • M12 FOV:80°
80
  • M12 FOV:100°
100
  • M12 FOV:120°
120
  • M12 FOV:140°
140
  • M12 FOV:160°
160
  • M12 FOV:200°
200
Was this article helpful to you? Yes 5 No
