Arducam team just released an 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface.
It is supplementary for Raspberry Pi official camera in order to fulfill the demands for different lens mount, the field of view (FOV) and depth of the field (DOF), as well as the motorized IR cut filter for both daylight and night vision.
There is a wide range of lens options which you can choose from us.
Models in this Series
There are 8 cameras in this series. The differences between them are field of view, IR sensitivity, lens mount and board size. They are the same in terms of software operation.
SKU | Field of View | IR Sensitivity | Lens Mount |
B0286 | 220°H | Visible Light | M12 |
B0194 | 145°H | NoIR | M12 |
B0188 | 75°H | NoIR | M12 |
B0184 | 75°H | Visible Light | M12 |
B0153 | 70°H | NoIR | CS |
B0102 | 70°H | Visible Light | CS |
B0152 | 70°H | NoIR | M12 |
B0103 | 70°H | Visible Light | M12 |
Too short camera cable?
You may need Arducam 30cm Sensor Extension Cable which extends the small camera module with a much longer distance and fit into the space-constrained environment.
Common Specs
General Specifications
Sensor Model | IMX219 |
Resolution | 8MP |
Pixel Size | 1.12μm×1.12μm |
Data Format | Raw Bayer 10bit |
IMX219 Full Datasheet
Refer here:
https://www.arducam.com/downloads/modules/RaspberryPi_camera/IMX219DS.PDF
Quick Start Guide
Hardware Setup
3.Insert the ribbon cable
4.Push the plastic clip down
Software Setup
Beginner Graphic Tutorial
Getting started with Raspberry Pi
Basic Camera Usage
Once installed, there are various ways the cameras can be used. The simplest option is to use one of the provided camera applications. There are four Linux command-line applications installed by default (e.g. raspistill
): using these is described on this page.
You can also programatically access the camera using the Python programming language, using the picamera
library.
Advanced Camera Usage
Advanced features, along with some hints and tips, are described in the following pages:
- Using RAW
- Long exposures
- Directly accessing sensors
- Using V4L2 to access the camera (e.g. Using Pi cameras as webcams)
- Removing the HQ camera IR filter
