Cameras for Raspberry Pi
  3. Cameras for Raspberry Pi
  4. Native Raspberry Pi Cameras
  5. 8MP IMX219 Motorized IR-CUT Camera Module
Arducam 8MP IMX219 Motorized IR-CUT Camera Module is designed for both daylight and night vision photography. The motorized IR cut filter can be switched ON/OFF automatically according to the light environment. The camera in this serial is fully supported by all the Raspberry Pi board versions including Pi 4/3B+/3. It can be widely used in wildlife photography, agriculture NDVI applications and etc.
Models in this Series
There are two cameras in this series. The difference between them is whether there are infrared LEDs. They are the same in terms of software operation.
B0154
Common Specs
General Specifications
Sensor ModelIMX219
Shutter TypeRolling Shutter
Active Pixels3280 (H) × 2464 (V)
Resolution8MP
Image Sensor FormatType 1/4″
Pixel Size1.12μm×1.12μm
CSI-2 Data Output2-lane mode
Data FormatRaw Bayer 10bit
IMX219 block diagram
IMX219 Block Diagram
IMX219 Full Datasheet
Refer here:
https://www.arducam.com/downloads/modules/RaspberryPi_camera/IMX219DS.PDF
Lens Assembly
InterchangeabilityYES
F/NO2.4
Focus TypeManual Focus
Focal Length1.8mm
Field of View(FoV)100° Horizontal
Lens MountM12 Lens
IR SensitivityMotorized IR Cut filter
Board
Camera Board Size36×36 mm
Connector & Cable
Connector InterfaceMIPI CSI-2 15-pin 2-lane
Ribbon Cable Length150mm
Quick Start Guide
Hardware Setup​​​​​​
raspberry pi zero overhead.00 00 00 19.Still001 1
SPRK default preset name web 1920 – 1
3.Insert the ribbon cable
4.Push the plastic clip down
Software Setup​​
Note:
If you are running the latest version of Raspberry Pi OS. (January 28th,2022 or later releases, Debian version:11(Bullseye)). You need to update the config file and use libcamera apps.
  • For Raspberry Bullseye users running on Pi 4, please do the following:
sudo nano /boot/config.txt
Find the line: camera_auto_detect=1, update it to:
camera_auto_detect=0
dtoverlay=imx219
Save and reboot.
  • For Bullseye users running on Pi 0 ~ 3, please also:
Open a terminal
Run sudo raspi-config
Navigate to Advanced Options
Reboot your Pi
Open a terminal
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
  • For Raspberry Pi Compute Module 3/4
The latest software only supports one camera at this time, CM4 uses CAM1 by default.
If you are running the previous system (Buster legacy and the system before it), you can refer to the Basic Camera Usage below.
Beginner Graphic Tutorial
Getting started with Raspberry Pi
Basic Camera Usage
Once installed, there are various ways the cameras can be used. The simplest option is to use one of the provided camera applications. There are four Linux command-line applications installed by default (e.g. raspistill): using these is described on this page.
You can also programatically access the camera using the Python programming language, using the picamera library.
Advanced Camera Usage
Advanced features, along with some hints and tips, are described in the following pages:
FAQ/Troubleshooting
The use of the four Raspberry Pi camera applications
FAQ about raspberry pi camera module
Was this article helpful to you? Yes No 1
