Arducam PT camera can move in two dimensions with 180 degrees horizontal and 145 degrees vertical movements. So it can be used to monitor places that should be covered by multiple ones commonly in the surveillance system.
Arducam PTZ cameras are the complete solution to turn your Raspberry Pi cameras into a fully functional surveillance camera that covers 360 degrees space. With the software autofocus function, you can clearly focus on your target when zooming. The IRCUT control also helps both the daylight and night vision.
Models in this Series
There are two cameras in this series. The main difference between them is whether the lens can be zoomed. If you wanna a 5MP PTZ camera, B01675MP and Pan Tilt Digital Servo Kit are needed.
Common Specs
Sensor Model | OV5647 |
Active Pixels | 2592×1944 |
Resolution | 5MP |
Pixel Size | 1.4μm×1.4μm |
OV5647 Full Datasheet
Refer here:
https://www.arducam.com/downloads/modules/RaspberryPi_camera/OV5647DS.pdf
Quick Start Guide
Hardware Setup for B0033PT
Hardware Setup for B01675MP
Connect the Camera Module to RPi with Ribbon Cable
The camera module connects to the RPi with a ribbon cable.
- To connect to the standard RPi, such as Pi 4, use the included 15pin-15pin white ribbon cable.
- To connect to Pi Zero and Compute Module, prepare a 15pin-22pin cable on your own.
The ribbon cable establishes a connection to the RPi and camera module with the help of metal contacts.
- The ribbon cable comes with metal contacts on both ends, but different sides.
- The camera module comes with metal contacts on the camera connector, beside the lens mount
- The RPi also comes with metal contacts on its CSI camera connector, beside the HDMI connector
Therefore, to ensure we are connecting the components in the correct way, just make sure the metal contacts of the ribbon cable are touching those of the camera module and the RPi on both ends.
3.Insert the ribbon cable
4.Push the plastic clip down
Connect the Servo Motors
The metal base with servos and jumper wire are not included in the package.
Connect the 3-pin plug of the servo motors to the two sockets of the driver controller board.
- The left socket is for the pan servo, and the right socket is for the tilt servo.
- Note the color of the 3-pin plug. It’s brown, red and yellow from left to right.
You can refer to Picture 1.
Connect the driver controller board jumpers
The jumpers of the driver controller board can be separated into 3 pairs, and they are mainly for two purposes: I2C control signals and power supplies.
- The 1st pair connects to external power, with Pin#1 being Servo VCC and Pin#2 GND.
- The 2nd pair connects to the RPi’s GPIO pins for power, with Pin#3 being 5V and Pin#4 GND.
- The 3rd pair also connects to the RPI’s GPIO pins for I2C, with Pin#5 being SCL and Pin#6 SDA.
You can refer to Picture 2.
Please note that In this illustrator, the different colors of the jumper wires are just to make it easier to distinguish them from each other. The order of those colors varies from item to item, so it may not match the one you’ve received. Therefore, instead of its color, you should rely on the position of the wire to correctly connect the jumpers.
After you finish the hardware assemble process, refer to Picture 3 to review the connections you’ve made.
Software Setup Preparation
- Start up your Raspberry Pi.
- Go to the main menu and open the Raspberry Pi Configuration tool.
- Select the Interfaces tab and ensure that the camera is enabled:
- Reboot your Raspberry Pi.
Using the Arducam PT Camera Example for B0033PT
1. Clone the demo code
git clone https://github.com/Arducam/PCA9685.git
2. Enter the target Directory
cd PCA9685/
3. Comile
make
4.Run the demo
sudo ./RunServoDemo
Using the Arducam PTZ Camera Example for B01675MP
Arducam offers example codes for pan, tilt, zoom, and auto-focus the camera module. You can also modify the example code to better suit your applications.
1. Enable I2C on the Raspberry Pi
As we mentioned above, the driver controller board need I2C as the control signal. Therefore, we have to enable the I2C on the Raspberry Pi first.
We will edit the config.txt
to enable the I2C on RPi.
- In your Terminal, type the following command then hit
Enter
sudo nano /boot/config.txt
Now we will edit the config.txt file.
- Use
to navigate to the bottom of the config.txt file, and - Add the following line to it as the picture shows.
dtparam=i2c_arm=on
Save the change and exit.
- Press
Ctrl+o
to save the changes, then hitEnter
- Press
Ctrl+x
to exit.
After you exit Nano, go back to the Terminal and reboot so the changes can take effect.
Enter
sudo reboot
2. Install python-opencv
Enter
3. Download and run the examples
Firstly, we will download the Arducam_OBISP_MIPI_Camera_Module library.
Enter
to download the library:
git clone https://github.com/ArduCAM/PTZ-Camera-Controller
Enter
to enter the target folder:
cd PTZ-Camera-Controller/pyCode
Enter
to run the demo:
python FocuserExample.py
Focus Example
1.Focuser.py
- zoom-lens basic control component.
2.AutoFocus.py
- Provide two autofocus methods are available, depending on Focuser.py, opencv, picamera
- Use the
command to install opencv.
3.AutoFocusExample.py
- Example of using autofocus, depending on AutoFocus.py
4.FocuserExample.py
- zoom-lens controller.
Here are some tips for using the demo example:
- After you run the focuser example, you will see instructions in the terminal. Read through the instructions for how to operate with the keys.
- Press
R
to reset the lens before pressingEnter
to start autofocus.
