Arducam 5MP OV5647 Motorized IR-CUT Camera Modules are designed for both daylight and night vision photography. The motorized IR cut filter can be switched ON/OFF automatically, and the infrared LEDs are automatically ON/OFF according to the light environment. The cameras in this serial are fully supported by all the Raspberry Pi board versions including Pi 4, Pi 3 and Pi Zero. They can be widely used in wildlife photography, agriculture NDVI applications and etc.
Models in this Series
There are two cameras in this series. The difference between them is whether there are infrared LEDs. They are the same in terms of software operation.
Common Specs
Sensor Model | OV5647 |
Active Pixels | 2592×1944 |
Resolution | 5MP |
Pixel Size | 1.4μm×1.4μm |
OV5647 Full Datasheet
Refer here:
https://www.arducam.com/downloads/modules/RaspberryPi_camera/OV5647DS.pdf
Lens Assembly
Interchangeability | YES |
F/NO | 2.3 |
Focus Type | Manual Focus |
Focal Length | 2.3mm |
Field of View(FoV) | 105° Horizontal |
Lens Mount | M12 Lens |
IR Sensitivity | Motorized IR Cut filter |
Board
Camera Board Size | 36×36 mm |
Connector & Cable
Ribbon Cable Length | 150mm |
Quick Start Guide
Hardware Setup
3.Insert the ribbon cable
4.Push the plastic clip down
Software Setup
Beginner Graphic Tutorial
Getting started with Raspberry Pi
Basic Camera Usage
Once installed, there are various ways the cameras can be used. The simplest option is to use one of the provided camera applications. There are four Linux command-line applications installed by default (e.g. raspistill
): using these is described on this page.
You can also programatically access the camera using the Python programming language, using the picamera
library.
Advanced Camera Usage
Advanced features, along with some hints and tips, are described in the following pages:
- Using RAW
- Long exposures
- Directly accessing sensors
- Using V4L2 to access the camera (e.g. Using Pi cameras as webcams)
- Removing the HQ camera IR filter
