Arducam 5MP OV5647 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see.
Models in this Series
There are two cameras in this series. The main difference between them is the camera board size. They are the same in terms of software operation.
SKU | Case | Camera Board Size |
B0176 | √ | 25×24 mm |
B0121 | × | 40×40 mm |
Common Specs
Sensor Model | OV5647 |
Active Pixels | 2592×1944 |
Resolution | 5MP |
Pixel Size | 1.4μm×1.4μm |
OV5647 Full Datasheet
Refer here:
https://www.arducam.com/downloads/modules/RaspberryPi_camera/OV5647DS.pdf
Lens Assembly
SKU | B0176 | B0121 |
Interchangeability | No | No |
Focus Distance | 4 cm to infinity | 4 cm to infinity |
Focus Type | Motorized Focus | Motorized Focus |
Field of View(FoV) | 54°H×44°V | 54°H×41°V |
IR Sensitivity | Visible Light | Visible Light |
Camera Board
B0167 | 25×24 mm |
B0121 | 40×40 mm |
Connector & Cable
Ribbon Cable Length | 150mm |
Quick Start Guide
Hardware Setup
3.Insert the ribbon cable
4.Push the plastic clip down
Software Setup
Preparation
- Start up your Raspberry Pi.
- Go to the main menu and open the Raspberry Pi Configuration tool.
- Select the Interfaces tab and ensure that the camera is enabled:
- Reboot your Raspberry Pi.
First Use
1.Clone the file
git clone https://github.com/ArduCAM/RaspberryPi.git
2.Install Python Dependency libraries
3.Enable the I2C0 adapter
cd RaspberryPi/Motorized_Focus_Camera chmod +x enable_i2c_vc.sh ./enable_i2c_vc.sh
Then press ‘y’ to reboot.
4.Demo code
4.1 Motorized_Focus_Camera_Preview.py
This demo supports focusing in preview mode. Single focus by keyboard up and down arrow.
cd RaspberryPi/Motorized_Focus_Camera sudo python Motorized_Focus_Camera_Preview.py
4.2 Motorized_Focus_Camera_Snapshot.py
This demo supports focusing and save the image to the local filesystem. You can save the image after each focus. Single focus by keyboard up and down arrow.
cd RaspberryPi/Motorized_Focus_Camera sudo python Motorized_Focus_Camera_Snapshot.py
4.3 Autofocus.py
This demo supports auto focusing in preview mode.
cd RaspberryPi/Motorized_Focus_Camera sudo python Autofocus.py
