- Introduction
- What is Camarray
- Common Specs
- Image sensor
- Lens Assembly
- Camera Board
- Connector & Cable
- Driver Performance (With Official V4L2 Driver)
- Frame rates (adjustable: 5fps~50fps)
- Quick Start Guide
- Hardware Setup
- Driver Installation
- First Use
- Display Images via VLC Media Player
- Display Images via Mplayer
- What’s Next
- Application Note
This Arducam 2MP*2 Stereo Camera MIPI Module is a stereo camera module with two synchronized monochrome global shutter OV2311 image sensors (2×2MP). It directly connects to the MIPI CSI-2 connectors of Raspberry Pi and Jetson Nano, and runs with a V4L2 camera driver on those platforms. It offers better flexibility to be integrated into your own hardware design or run with your own algorithm on embedded systems for applications like depth sensing, 3d mapping, SLAM, etc.
What is Camarray
NOTE
Common Specs
Image sensor
Sensor Model | OV2311 |
Active Pixels | 1600*2×1300 |
Resolution | 2MP*2 |
Image Sensor Format | Type 1/2.9″ |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Field of View(FoV) | 83° Horizontal |
Lens Mount | M12 Lens |
Camera Board
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Ribbon Cable Length | 150mm (15-pin), 150mm (15-22pin) |
Mating connector type | SFW15R-2STE1LF |
1 | GND | Power | Ground |
2 | CAM_D0_N | Output | MIPI Data Lane 0 Negative |
3 | CAM_D0_P | Output | MIPI Data Lane 0 Positive |
4 | GND | Power | Ground |
5 | CAM_D1_N | Output | MIPI Data Lane 1 Negative |
6 | CAM_D1_P | Output | MIPI Data Lane1 Positive |
7 | GND | Power | Ground |
8 | CAM_CK_N | Output | MIPI Clock Lane Negative |
9 | CAM_CK_P | Output | MIPI Clock Lane Positive |
10 | GND | Power | Ground |
11 | CAM_IO0 | Input | Power Enable |
12 | CAM_IO1 | Input | LED Indicator |
13 | CAM_SCL | Bidirection | I2C SCL |
14 | CAM_SDA | Bidirection | I2C SDA |
15 | CAM_3V3 | Power | 3.3V Power Input |
Raspberry Pi | Jetson Nano | |
RAW8(GREY) | [email protected]×1300 | [email protected]×1300 |
RAW10(Y10P) | [email protected]×1300 | [email protected]×1300 |
Quick Start Guide
Hardware Setup
Driver Installation
1.Driver note
- Official driver
- Arducam MIPI camera driver
- Arducam V4L2 driver
1)Arducam MIPI camera driver is not in conflict with the official driver.
2)Arducam V4L2 driver is in conflict with the official driver. If you want to use the official driver, you need to uninstall the Arducam V4L2 driver first.
3)Arducam V4L2 driver is in conflict with Arducam MIPI camera driver. If you want to use the Arducam MIPI camera driver, you need to uninstall the Arducam V4L2 driver first.
4)Arducam V4L2 driver automatically overwrites the other two drivers. After uninstalling the Arducam V4L2 driver, it automatically reverts to the official driver.
2.Check the driver
Check if the system is installed with the Arducam V4L2 driver.
sudo nano /boot/config.txt
Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
1)If you see “dtoverlay=arducam”, the Arducam V4L2 driver has been previously installed and is in a valid state.
2)If you see “#dtoverlay=arducam”, it means you have installed Arducam V4L2 driver before, but it is uninstalled now, remove the “#” to restore the V4L2 driver. Then reboot Pi to take effect.
3)If you don’t see “dtoverlay=arducam” or “#dtoverlay=arducam”, it means that Arducam’s V4L2 driver has never been installed before, so you need to follow the instructions below for a complete installation.
3. Install Arducam v4l2 driver
#Download driver package
#Extract the archive files
tar zxvf Release.tar.gz
#Enter the extracted folder
cd Release/
#Install the driver
./install_driver.sh
#Reboot the device
Press y
, and then hit Enter
to reboot.
Get an error?
If your operating system is not released by official Raspberry Pi, the driver installation will report an error and give a version error message.
Check out Raspberry Pi official supported operating system:
4. Uninstall the driver
Note that the driver will occupy CSI hardware resources. After installation, you will not be able to use the raspistill tool. There are two ways to uninstall Arducam V4L2 driver:
cd Release/
./uninstall_driver.sh
NOTE
You have to reboot your Pi to make it effect.
Method 2: Modify configuration files
1.Type the following command:
2.Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
Modify “dtoverlay=arducam” as “#dtoverlay=arducam” to uninstall the V4L2 driver. Press 【Ctrl+X】, 【Y】,【Enter】to save the change and exit.
NOTE
First Use
1.Check whether the camera is detected
ls /dev/video0
2.Check the video format supported
v4l2-ctl --list-formats-ext
At present, only “GREY” and “Y10P” formats are supported, and “Y10” format is not supported.
Run the command without results?
You might have to check the ribbon connection or install the drivers correctly, then reboot the Raspberry Pi.
3.Preview the camera feed
#RAW10
arducamstill -t 0 -pixfmt Y10P -w 3200 -h 1300
#RAW8
arducamstill -t 0 -pixfmt GREY -w 3200 -h 1300
The last line shows frame in real time.
GREY for RAW8 and Y10P for RAW10.
-w and -h indicate the width and height of the input image.
Press Ctrl+C to exit the preview.
4.Receive data without displaying the image
#RAW8
v4l2-ctl --set-fmt-video=width=3200,height=1300,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=3200,height=1300,pixelformat='Y10P' --stream-mmap --stream-count=-1 -d /dev/video0
5.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
6. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=200
7.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 35. First, open two terminals, type the following command in the first terminal:
v4l2-ctl -c frame_rate=35
v4l2-ctl -l
IMPRORTANT NOTE
For example, if the frame rate is set to 50 fps, the display only goes up to 30fps.
But when you use only receiving data without displaying the image, the frame rate goes back to 50fps. (The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.)
You can display images in real time via the VLC media player.
(The VLC media player can only play images that are output in RAW8 format.)
1.Open VLC media plyer
2.Select 【Media】→【Open Capture Device…】
3.【Video device name】→ select “/dev/video0“→ click 【Play】.
It may be stuck due to Raspberry Pi performance and VLC media player.
4.Adjust the exposure, gain, and frame rate
【Tool】→【Effects and Filters】
Drag the different slider to adjust the corresponding parameter.
1.Install mplay
sudo apt-get install mplayer
2.Display images
The image screen may be too large for the display to be complete. You need to drag the title bar to move the window to see the full image.
Right-click on the mplayer title bar and select 【Maximize】. Then you can see see the full image. (The image is pretty smooth.)
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1600 -y 650
What’s Next
Application Note
Depth Mapping on Raspberry Pi
1.Install Driver
Please refer to this page for a driver demonstration.
2.Hardware Setup
3.Reboot RPi
After rebooting RPi, use ls /dev/video* command to see the video device.
4.Software Setup
4.1 Download the demo code
git clone https://github.com/ArduCAM/3d-camera.git
cd 3d-camera/stereo-camera/RaspberryPi/stereo_depth_demo/
4.2 Install Dependency for Python3.X
Latest Raspbian version is recommended.
sudo apt-get update && sudo apt-get install -y libhdf5-dev libhdf5-serial-dev libatlas-base-dev libjasper-dev libqtgui4 libqt4-test && sudo pip3 install opencv-python==3.4.6.27
sudo pip3 install stereovision
sudo pip3 install matplotlib
5.Run the Programs
5.1 Capture Images
python 1_test.py
Help message:
Example:
5.2 Collect Images for Calibration
python 2_chess_cycle.py
5.3 Separate Captured Images
python 3_pairs_cut.py
5.4 Calibration
python 4_calibration.py
5.5 Depth Map Tuning
python 5_dm_tune.py
5.6 Real-Time Depth Map Using Video
python 6_dm_video.py
