  3. Cameras for Raspberry Pi
  4. Arducam MIPI Camera Modules
  5. OV7251 0.3MP Global Shutter Camera for Raspberry Pi
The Arducam OV7251 MIPI camera module incorporates Omnivision 1/7.5-inch 0.3 Mp CMOS digital image sensor which is capable of operating at up to 100fps in VGA (640×480) resolution. The OV7251’s high frame rates make it an ideal solution for low-latency machine vision applications.
The global shutter technology allows to reduce or eliminate unwanted image artifacts, which occur with traditional rolling shutter image sensors as a result of motion during image capture. The sensor’s global shutter and excellent low-light sensitivity allow it to be used for any application that needs gesture detection, head/eye tracking, and depth and motion detection.
Key Specification
Optical format1/7.5−inch
Active pixels640 (H) × 480 (V)
Pixel size3μm x 3μm
Color filter arrayMonochrome
Build-in FilterOptional, 650nm by default,
other requirement please contact us
Shutter TypeGlobal Shutter
ADC resolution8/10-bit BW RAW
Responsivity10.8 V/lux-sec (850nm)
Dynamic range[email protected] gain
SNRMAX39dB
Frame RateFull Resolution (640H x 480V) @100fps
EFL1.3
F.NO2.2
FOVD86.5⁰ /H72.9⁰ /V57.7⁰
Hardware Connection
Camera driver and Examples
The SDK library and example source code can be download from our GitHub. Software user guide can be found from here.
Pin Definition
The camera module using Molex 0522711579 or similar 15pin 1mm pitch FPC connector.
1 GND Ground Power ground
2 MDN0 Input Pixel Data Lane0 Negative
3 MDP0 Input Pixel Data Lane0 Positive
4 GND Ground Power ground
5 NC NC NC
6 NC NC NC
7 GND Ground Power ground
8 MCN Input Pixel Clock Output Form Sensor Negative
9 MCP Input Pixel Clock Output Form Sensor Positive
10 GND Ground Power ground
11 POWER_EN Output Power Enable
12 LED-EN Input Led Enable
13 SCL Input Two-Wire Serial Interface Clock
14 SDATA Bi-directional Two-Wire Serial Interface Data I/O
15 VCC_3.3V POWER 3.3v Power supply
Mechanical Dimension
Order Information
Check the Raspberry PI Cameras from the product page.
Was this article helpful to you? Yes No 1
