Arducam MIPI Camera SDK provides the following APIs for MIPI camera
- arducam_init_camera: init camera
- arducam_init_camera2: init camera with specific interface
- arducam_set_resolution: Set output resolution.
- arducam_set_mode: brief Set sensor mode.
- arducam_get_format: brief Get the current format.
- arducam_set_video_callback: Set video data output callback.
- arducam_set_raw_callback: Set raw data output callback.
- arducam_capture: Get single frame data.
- arducam_release_buffer: arducam_release_buffer.
- arducam_start_preview: Turn on image preview.
- arducam_stop_preview: Turn off image preview.
- arducam_close_camera: Release all resources and turn off the camera.
- arducam_reset_control: Set camera control to default value.
- arducam_set_control: Set camera control.
- arducam_get_control: Get camera control value.
- arducam_get_support_formats: Get the resolution supported by the current camera
- arducam_get_support_controls: Get the control parameters supported by the current camera
- arducam_write_sensor_reg: brief Write sensor register.
- arducam_read_sensor_reg: brief Read sensor register.
- arducam_software_auto_exposure: brief Enable/Disable software auto exposure
- arducam_software_auto_white_balance: brief Enable/Disable software auto white balance
- arducam_unpack_raw10_to_raw8: brief Helper function, use to unpack mipi raw10.
- arducam_unpack_raw10_to_raw16: brief Helper function, use to unpack mipi raw10.
- arducam_manual_set_awb_compensation: used to compensate the red channel gain and blue change gain.
int arducam_init_camera(CAMERA_INSTANCE *camera_instance);
- init camera.
- @param: camera_instance Pointer of type CAMERA_INSTANCE, use to
obtain CAMERA_INSTANCE. - @return error code , 0 success, !0 error.
- example:
@code
CAMERA_INStANCE camera_instance;
arducam_init_camera(&camera_instance);
@endcode
- example:
int arducam_init_camera2(CAMERA_INSTANCE *camera_instance, struct camera_interface cam_interface);
- init camera.
- @param camera_instance Pointer of type CAMERA_INSTANCE, use to obtain CAMERA_INSTANCE.
- @param camera_num Camera interface num.
- example:
@code
arducam_init_camera(&camera_instance, 0);
@endcode
@note Some boards have multiple camera interfaces.
- example:
int arducam_set_resolution(CAMERA_INSTANCE camera_instance, int *width, int *height);
- Set output resolution.
- @param camera_instance Type CAMERA_INSTANCE, Obtained from arducam_init_camera function.
- @param width Pointer of type int, Used to specify the width and return to the actual width.
- @param height Pointer of type int, Used to specify the height and return to the actual height.
- example:
@code
Int width = 1920;
Int height = 1080;
Int res = arducam_set_resolution(camera_instance, &width, &height);
@endcode
@note Some boards have multiple camera interfaces. - */
int arducam_set_mode(CAMERA_INSTANCEcamera_instance, int mode);
* @brief Set sensor mode
* @param camera_instance Type CAMERA_INSTANCE, Obtained from arducam_init_camera function.
* @param mode Mode index.(You can use the list_format program to view the supported modes.)
* @return error code , 0 success, !0 error.
@code
Int mode = 1;
Int res = arducam_set_mode(camera_instance, mode);
@endcode
int arducam_get_format(CAMERA_INSTANCE camera_instance, struct format *fmt);
- @brief Get the current format.
- @param fmt Pointer of type struct format, used to store format information.
- @return ierror code , 0 success, !0 error.
int arducam_set_video_callback(CAMERA_INSTANCE camera_instance,
VIDEO_ENCODER_STATE *encoder_state, OUTPUT_CALLBACK callback, void *userdata);
- Set video data output callback.
- @param encoder_state Used to specify encoding parameters. Use default parameters if NULL.
- @param callback Callback method, this method will be called when there is data return.
- @param userdata Userdata, which will be a member of the buffer parameter in the callback function.
- example:
@code
int video_callback(BUFFER *buffer) {
buffer->userdata;
// start callback
if(arducam_set_video_callback(camera_instance, NULL, video_callback, NULL)){
printf(“set video callback failed.”);
// stop callback
arducam_set_video_callback(camera_instance, NULL, NULL, NULL)
@endcode
@note Calling the arducam_set_resolution function before stopping video encoding will terminate the video encoding.
@note The buffer will be automatically released after the callback function ends.
- example:
int arducam_set_raw_callback(CAMERA_INSTANCE camera_instance, OUTPUT_CALLBACK
- Set raw data output callback.
- example:
@code
int raw_callback(BUFFER *buffer) {
buffer->userdata;
// start callback
if(arducam_set_raw_callback(camera_instance, raw_callback, NULL)){
printf(“set raw data callback failed.”);
// stop callback
arducam_set_raw_callback(camera_instance, NULL, NULL)
@endcode
@note If you do a time-consuming operation in the callback, it will affect other parts, such as preview, video encoding(This issue may be fixed in the future).
- example:
BUFFER *arducam_capture(CAMERA_INSTANCEcamera_instance, IMAGE_FORMAT *format, inttimeout);
- Get single frame data.
- @param format The data format to be obtained.
- @param timeout This method will return NULL if no data is obtained at this time.
- @return BUFFER structure pointer containing image data.
- example:
@code
IMAGE_FORMAT fmt = {IMAGE_ENCODING_JPEG, 50};
BUFFER *buffer = arducam_capture(camera_instance, &fmt, 3000);
if (!buffer) {
LOG(“capture timeout.”);
return;
@endcode
@note Currently supported image formats are:
IMAGE_ENCODING_JPEG, IMAGE_ENCODING_I420, IMAGE_ENCODING_RAW_BAYER
@note When the buffer is used, you need to call the arducam_release_buffer function to release it.
@note The actual width and height of the raw bayer format and the yuv420 format are aligned, width 32 bytes aligned, and height 16 byte aligned.
- example:
void arducam_release_buffer(BUFFER *buffer);
- Used to release the memory occupied by the buffer.
- @param buffer The buffer to be released.
int arducam_start_preview(CAMERA_INSTANCE camera_instance, PREVIEW_PARAMS
*preview_params);
- Turn on image preview
- @param preview_params Preview parameter,Use default parameters if NULL.
int arducam_stop_preview(CAMERA_INSTANCEcamera_instance);
- Turn off image preview
int arducam_close_camera(CAMERA_INSTANCEcamera_instance);
- Release all resources and turn off the camera.
int arducam_reset_control(CAMERA_INSTANCE *camera_instance, intctrl_id);
- Set camera control to default value.
- @param ctrl_id Control id.
- example:
@code
arducam_reset_control(camera_instance, V4L2_CID_EXPOSURE);
@endcode
- example:
int arducam_set_control(CAMERA_INSTANCEcamera_instance, int ctrl_id, intvalue);
- Set camera control.
- @param value Control value.
- example:
@code
arducam_set_control(camera_instance, V4L2_CID_EXPOSURE, 3000);
@endcode
- example:
int arducam_get_control(CAMERA_INSTANCE camera_instance, intctrl_id, int *value);
- Get camera control value.
- @param value Current control value.
- example:
@code
int exposure = 0;
arducam_get_control(camera_instance, V4L2_CID_EXPOSURE, &exposure);
printf(“Current exposure is %d\n”, exposure);
@endcode
- example:
int arducam_get_support_formats(CAMERA_INSTANCEcamera_instance, struct format *fmt, int index);
- Get the resolution supported by the current camera
- @param fmt Used to return resolution parameters.
- @param index Format list index.
- example:
@code
struct format support_fmt;
unsigned int index = 0;
while (!arducam_get_support_formats(camera_instance, &support_fmt, index++)) {
printf(“index: %d, width: %d, height: %d\n”, index, support_fmt.width,
support_fmt.height);
@endcode
- example:
int arducam_get_support_controls(CAMERA_INSTANCEcamera_instance, struct camera_ctrl *cam_ctrl, int index);
- Get the control parameters supported by the current camera.
- @param cam_ctrl Used to return control parameters.
- @param index Control list index.
- example:
@code
struct camera_ctrl support_cam_ctrl;
while (!arducam_get_support_controls(camera_instance, &support_cam_ctrl, index++)) {
int value = 0;
if (arducam_get_control(camera_instance, support_cam_ctrl.id, &value)) {
printf(“Get ctrl %s fail.\n”, support_cam_ctrl.desc);
printf(“index: %d, CID: 0x%08X, desc: %s, min: %d, max: %d, default: %d, current: %d\n”,
index, support_cam_ctrl.id, support_cam_ctrl.desc, support_cam_ctrl.min_value,
support_cam_ctrl.max_value, support_cam_ctrl.default_value, value);
@endcode
- example:
int arducam_write_sensor_reg(CAMERA_INSTANCE camera_instance, uint16_t address,
uint16_t value);
- @brief Write sensor register.
- @param camera_instance camera_instance Type CAMERA_INSTANCE, Obtained from arducam_init_camera function.
- @param address Sensor register address.
- @param value The value you want to write
int arducam_read_sensor_reg(CAMERA_INSTANCE camera_instance, uint16_t address,
uint16_t *value);
- @brief Read sensor register.
- @param value The address of the variable that stores the result.
int arducam_software_auto_exposure(CAMERA_INSTANCE camera_instance, int enable);
- @brief Enable/Disable software auto exposure.
- @param enable 0 disable, !0 enable.
- @note Calling the arducam_set_resolution function will turn off this feature.
int arducam_software_auto_white_balance(CAMERA_INSTANCE camera_instance, intenable);
- @brief Enable/Disable software auto white balance.
BUFFER *arducam_unpack_raw10_to_raw8(uint8_t *buff_in, int width, int height);
- @brief Helper function, use to unpack mipi raw10.
- @param buff_in Raw10 data buffer.
- @param width Image width
- @param height Image height
- @note This function will remove the part that is filled because of the alignment,
- @note for example, the height is 1080, because the height needs 16 is the alignment,
- @note so the actual pixel height is 1088. After passing the height of 1080 using this
- @note function, the actual pixel height of the output is 1080.
- @note The performance of this function is not very good.
BUFFER *arducam_unpack_raw10_to_raw16(uint8_t *buff_in, intwidth, int height);
void arducam_manual_set_awb_compensation(uint32_t r_gain, uint32_t b_gain);
- @brief set awb function, use to compensation the rgain and bgain
- @param r_gain the red channel compensation
- @param b_gain the blue channel compensation
