Cameras for Raspberry Pi
  3. Cameras for Raspberry Pi
  4. Arducam MIPI Camera Modules
  5. IMX135 13MP Color Rolling Shutter Camera for Raspberry Pi
Arducam IMX135 MIPI camera module incorporates Sony 1/3−inch 13 Mega-pixel CMOS active pixel type stacked image sensor with a square pixel array. The MIPI camera module supports manual exposure, white balance and focus adjustment, and be connected to the standard Raspberry pi CSI-2 camera port. It also supports other hardware platforms with the MIPI camera interface like Nvidia Jetson TX2.
Arducam developed a special camera driver for Raspberry Pi, which lets you can capture 13MP still image and 1080p video on your existing Pi board.
Key Specification
Optical format 1/3−inch
Active pixels 4208H x 3120V
Pixel size 1.12um x 1.12um
Color filter array RGB Bayer pattern
ADC resolution 10−bit, on−chip
Responsivity 0.62 V/lux−sec (545 nm)
Output Interface 2-Lane /4-Lane MIPI
Frame Rate 13 Mp full resolution at 24 fps
720p at 60 fps
1080 at 30 fps
Hardware Connection
Camera driver and Examples
The SDK library and example source code can be download from our GitHub. Software user guide can be found from here.
Pin Definition
Pin No.PIN NAME TYPE DESCRIPTION
1GND Ground Power ground
2MDN0 Input Pixel Data Lane0 Negative
3MDP0 Input Pixel Data Lane0 Positive
4GND Ground Power ground
5MDN1 Input Pixel Data Lane1 Negative
6MDP1 Output Pixel Data Lane1 Positive
7GND Ground Power ground
8MCN Input Pixel Clock Output Form Sensor Negative
9MCP Input Pixel Clock Output Form Sensor Positive
10GND Ground Power ground
11MDN2 Input Pixel Data Lane2 Negative
12MDP2 Input Pixel Data Lane2 Positive
13GND Ground Power ground
14MDN3 Input Pixel Data Lane3 Negative
15MDP3 Input Pixel Data Lane3 Positive
16GND Ground Power ground
17POWER_EN Output Power Enable
18VCC_3.3V POWER 3.3v Power supply
19GND Ground Power ground
20SCL Input Two-Wire Serial Interface Clock
21SDATA Bi-directional Two-Wire Serial Interface Data I/O
22VCC_3.3V POWER 3.3v Power supply
Mechanical Dimension
Order Information
Check the Raspberry PI Cameras from the product page.
Was this article helpful to you? Yes 1 No 2
