Cameras for Raspberry Pi
  3. Cameras for Raspberry Pi
  4. 64MP Camera Modules
  5. Arducam 64MP Synchronized Quad Camera-Troubleshooting
1. Error messages like this
Cannot find the corresponding package, please send the following information to [email protected]
Hardware Revision: b03111
Kernel Version: 5.4.83-v7l+
How to fix it
Try a fresh install of Raspberry Pi OS:
Do not run rpi-update!
2. “failed to import” error
1657097384165 7736B14A AB91 4e95 A6FA 062647A2E59B 1
How to fix it:
For Raspbian Bullseye users running on Pi Zero ~ Pi 3, please execute the follows:
1. Open a terminal
2. Run sudo raspi-config
3. Navigate to Advanced Options
4. Enable Glamor graphic acceleration
5. Reboot your Pi
Meanwhile, you also need to execute the following steps:
1. Open a terminal
4. Navigate to GL Driver
5. Select GL (Full KMS)
6. Reboot your Pi
3. Error message when install libcamera
Setting up libcamera-apps (0.0.7) ...
W: Repository is broken: libcamera-apps:armhf (= 0.0.7) has no Size information
How to fix it:
This error is just a hint and does not affect the installation and continued using of libcamera.
4. Error message when using libcamera apps
[0:06:53.738043852] [1657]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+                             3572-e13ccdd5
No cameras available!
libcamera-still -t 0
Made X/EGL Preview Window
[0:12:13.562388581] [1462]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
ERROR: *** no cameras available ***
Please input ls /dev/video* to check if there is /dev/video0
ls /dev/video*
/dev/video10  /dev/video12  /dev/video14  /dev/video16  /dev/video20  /dev/video22  /dev/video31
/dev/video11  /dev/video13  /dev/video15  /dev/video18  /dev/video21  /dev/video23
If you can not find /dev/video0 like above, then you may missed some steps.
  • Check the connection of the camera and the pi
1657098495742 4DB24092 2AC3 4fc7 AD4C 38F02508681F
  • Check the steps of installing the driver again.
  • Check the config file
If you are using the camera on Pi 4, please make sure these items are under the line [pi4] like this:
Run sudo nano /boot/config.txt
If you are using the camera on CM4, please make sure these items are under the line [cm4] like this:
[cm4]
otg_mode=1
dtoverlay=arducam_64mp
dtoverlay=arducam_64mp,cam0
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
If you are using the camera on other Raspberry Pi platforms, please make sure these items are under the line [all] like this:
[all]
# Run as fast as firmware / board allows
arm_boost=1
