Arducam PT camera can move in two dimensions with 180 degrees horizontal and 145 degrees vertical movements. So it can be used to monitor places that should be covered by multiple ones commonly in the surveillance system.
Arducam PTZ cameras are the complete solution to turn your cameras into a fully functional surveillance camera that covers 360 degrees of space. With the software autofocus function, you can clearly focus on your target when zooming. The IRCUT control also helps both the daylight and night vision.
Models in this Series
- If you wanna an 8MP PTZ camera, B01678MP and Pan Tilt Digital Servo Kit are needed.
- If you wanna an 8MP PT camera, a Raspberry Pi V2 camera or V2-Sized IMX219 camera and Arudcam Pan Tilt Platform are needed. (B0283 is an upgraded version of B0227 with improved bracket quality and a mini customized control board.)
- If you wanna run two 8MP PT camera, get B0191PT.
Quick Start Guide
Hardware Setup
For B01678MP
Connect the Camera Module to Jetson with Ribbon Cable
- Locate the camera connector (CSI). It’s on the side of the carrier board, opposite to the GPIO pins.
- Pull up on the plastic edges of the camera port. Do it gently to avoid pulling it off.
- Push in the camera ribbon. Make sure the contacts are facing the heatsinks. Do not bend the flex cable, and make sure it’s firmly inserted into the bottom of the connector.
- Push the plastic connector down. Do it while holding the flex cable until the connector is back in place.
Connect the Servo Motors
The metal base with servos and jumper wire are not included in the package.
Connect the 3-pin plug of the servo motors to the two sockets of the driver controller board.
- The left socket is for the pan servo, and the right socket is for the tilt servo.
- Note the color of the 3-pin plug. It’s brown, red and yellow from left to right.
You can refer to Picture 1.
Connect the driver controller board jumpers
The jumpers of the driver controller board can be separated into 3 pairs, and they are mainly for two purposes: I2C control signals and power supplies.
- The 1st pair connects to external power, with Pin#1 being Servo VCC and Pin#2 GND.
- The 2nd pair connects to the RPi’s GPIO pins for power, with Pin#3 being 5V and Pin#4 GND.
- The 3rd pair also connects to the Jetson’s GPIO pins for I2C, with Pin#5 being SCL and Pin#6 SDA.
You can refer to Picture 2.
Please note that In this illustrator, the different colors of the jumper wires are just to make it easier to distinguish them from each other. The order of those colors varies from item to item, so it may not match the one you’ve received. Therefore, instead of its color, you should rely on the position of the wire to correctly connect the jumpers.
After you finish the hardware assemble process, refer to Picture 3 to review the connections you’ve made.
For B0283
For B0227
For B0191PT
Using the Arducam PTZ Camera Example for B01678MP
Download the demo code
git clone https://www.github.com/arducam/MIPI_Camera.git
Install Dependency
sudo apt install python-smbus
Enter the folder
cd MIPI_Camera/Jetson/JetsonNano_PTZ/
Run the demo code
python FocuserExample.py
Focus Example Demo
1.Focuser.py
- zoom-lens basic control component.
2.AutoFocus.py
- Provide two autofocus methods are available, depending on Focuser.py, opencv, picamera
- Use the
command to install opencv.
3.AutoFocusExample.py
- Example of using autofocus, depending on AutoFocus.py
4.FocuserExample.py
- zoom-lens controller.
Using the Arducam PT Camera Example for B0283/B0227/B0191PT
Install dependencies
sudo apt update sudo apt install python3-pip sudo pip3 install adafruit-circuitpython-servokit
Clone the demo code
git clone https://github.com/ArduCAM/PCA9685.git
Enter the target Directory
cd PCA9685/example/Jetson
Run the demo
python3 ServoKitExample.py
