Introdution
IMX219 is a 1/4″ 8MP MIPI CSI-2 image sensor, it was adopted by the Raspberry pi V2 camera module back in 2016. Now the IMX219 camera is natively supported by the Jetson Nano and Xavier NX out of the box. Arducam made a lot of variation of this camera to address different use-cases for Jetson fans.
Models in this Series
The main differences between these products are field of view and IR sensitivity. They are the same in terms of software operation.
SKU | Model | IR Sensitivity | Field of View |
B0286 | IMX219 drop in replacement | Visible Light | 220°H |
B0287 | IMX219 camera module | Visible Light | 220°H |
B0193 | IMX219 camera module | NOIR | 175°D x 145°H x 77°V |
B0179 | IMX219 camera module | Visible Light | 175°D x 145°H x 77°V |
B0194 | IMX219 drop in replacement | NoIR | 175°D x 145°H x 77°V |
B0188 | IMX219 drop in replacement | NoIR | 75°H |
B0184 | IMX219 drop in replacement | Visible Light | 75°H |
B0183 | IMX219 camera module | Visible Light | 75°H |
B0180 | IMX219 drop in replacement | Visible Light | 75°H |
B0191 | IMX219 camera module | Visible Light | 62.2°D |
Too short camera cable?
You may need Arducam 30cm Sensor Extension Cable which extends the small camera module with a much longer distance and fit into the space-constrained environment.
Common Specs
General Specifications
Sensor Model | IMX219 |
Resolution | 8MP |
Pixel Size | 1.12μm×1.12μm |
Data Format | Raw Bayer 10bit |
IMX219 Full Datasheet
Refer here:
https://www.arducam.com/downloads/modules/RaspberryPi_camera/IMX219DS.PDF
Quick Start Guide
Hardware Setup
- Locate the camera connector (CSI). It’s on the side of the carrier board, opposite to the GPIO pins.
- Pull up on the plastic edges of the camera port. Do it gently to avoid pulling it off.
- Push in the camera ribbon. Make sure the contacts are facing the heatsinks. Do not bend the flex cable, and make sure it’s firmly inserted into the bottom of the connector.
- Push the plastic connector down. Do it while holding the flex cable until the connector is back in place.
Software Setup
Please refer to this page:
https://developer.nvidia.com/embedded/learn/tutorials/first-picture-csi-usb-camera
Supported Resolution and Frame Rate
Using v4l2-ctl --list-formats-ext
command to list the supported resolution and frame rate combination on Jetson.
$ v4l2-ctl --list-formats-ext ioctl: VIDIOC_ENUM_FMT Index : 0 Type : Video Capture Pixel Format: 'RG10' Name : 10-bit Bayer RGRG/GBGB Size: Discrete 3280x2464 Interval: Discrete 0.048s (21.000 fps) Size: Discrete 3280x1848 Interval: Discrete 0.036s (28.000 fps) Size: Discrete 1920x1080 Interval: Discrete 0.033s (30.000 fps) Size: Discrete 1280x720 Interval: Discrete 0.017s (60.000 fps) Size: Discrete 1280x720 Interval: Discrete 0.017s (60.000 fps)
Examples of command line Gstreamer script
The following GStreamer examples help you to do a quite test on IMX219 for verification purposes. The sensor_id
parameter selects the camera: 0 or 1 on Jetson Nano B01/Xavier NX.
$ gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! nvoverlaysink
More specific – width, height and framerate are from supported video modes. Example also shows sensor_mode
parameter to nvarguscamerasrc
. See below for example video modes of example sensor.
$ DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! \ 'video/x-raw(memory:NVMM),width=3280, height=2464, framerate=21/1, format=NV12' ! \ nvvidconv flip-method=0 ! 'video/x-raw,width=960, height=720' ! \ nvvidconv ! nvegltransform ! nveglglessink -e
For some reason, the required resolution doesn’t match with driver settings, you should adjust accordingly. As an example, for 3264×2464 @ 21 fps on sensor_id 1 of a Jetson Nano B01 or Xavier NX:
$ DISPLAY=:0.0 gst-launch-1.0 nvarguscamerasrc sensor_id=1 ! \ 'video/x-raw(memory:NVMM),width=3264, height=2464, framerate=21/1, format=NV12' ! \ nvvidconv flip-method=0 ! 'video/x-raw, width=816, height=616' ! \ nvvidconv ! nvegltransform ! nveglglessink -e
Using the nvvidconv flip-method
parameter, it can rotate/flip the image, that is useful when the mounting of the camera with different orientation.
flip-method : video flip methods flags: readable, writable, controllable Enum "GstNvVideoFlipMethod" Default: 0, "none" (0): none - Identity (no rotation) (1): counterclockwise - Rotate counter-clockwise 90 degrees (2): rotate-180 - Rotate 180 degrees (3): clockwise - Rotate clockwise 90 degrees (4): horizontal-flip - Flip horizontally (5): upper-right-diagonal - Flip across upper right/lower left diagonal (6): vertical-flip - Flip vertically (7): upper-left-diagonal - Flip across upper left/low
Python Example
The following is the python example grabbed from JetsonHacks.
# MIT License # Copyright (c) 2019 JetsonHacks # See license # Using a CSI camera (such as the Raspberry Pi Version 2) connected to a # NVIDIA Jetson Nano Developer Kit using OpenCV # Drivers for the camera and OpenCV are included in the base image import cv2 # gstreamer_pipeline returns a GStreamer pipeline for capturing from the CSI camera # Defaults to 1280x720 @ 60fps # Flip the image by setting the flip_method (most common values: 0 and 2) # display_width and display_height determine the size of the window on the screen def gstreamer_pipeline( capture_width=1280, capture_height=720, display_width=1280, display_height=720, framerate=60, flip_method=0, ): return ( "nvarguscamerasrc ! " "video/x-raw(memory:NVMM), " "width=(int)%d, height=(int)%d, " "format=(string)NV12, framerate=(fraction)%d/1 ! " "nvvidconv flip-method=%d ! " "video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! " "videoconvert ! " "video/x-raw, format=(string)BGR ! appsink" % ( capture_width, capture_height, framerate, flip_method, display_width, display_height, ) ) def show_camera(): # To flip the image, modify the flip_method parameter (0 and 2 are the most common) print(gstreamer_pipeline(flip_method=0)) cap = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER) if cap.isOpened(): window_handle = cv2.namedWindow("CSI Camera", cv2.WINDOW_AUTOSIZE) # Window while cv2.getWindowProperty("CSI Camera", 0) >= 0: ret_val, img = cap.read() cv2.imshow("CSI Camera", img) # This also acts as keyCode = cv2.waitKey(30) & 0xFF # Stop the program on the ESC key if keyCode == 27: break cap.release() cv2.destroyAllWindows() else: print("Unable to open camera") if __name__ == "__main__": show_camera()
