This Arducam 8MP Synchronized Stereo Camera Bundle Kit is capable of running two 8MP IMX219 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Jetson Nano/Xavier NX. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. You can use this bundle to build your stereo camera system for depth-related vision applications or advanced surveillance cameras.
What is Camarray
NOTE
Common Specs
Image sensor
Sensor Model | IMX219 |
Resolution | 8MP*2 |
Pixel Size | 1.12μm×1.12μm |
Color Filter Array | 650nm |
Lens Assembly
Interchangeability | No |
F/NO | 2.0 |
Focus Type | Fixed Focus |
Field of View(FoV) | 62.2° Diagonal |
Board
HAT Size | 65×56 mm |
Camera Board Mechanical Drawing
HAT Mechanical Drawing
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Ribbon Cable Length | 80mm(22-pin), 73mm(15-22pin) |
Pin # | Name | Description |
1 | GND | Ground |
4 | GND | Ground |
7 | GND | Ground |
10 | GND | Ground |
11 | CAM_IO0 | Power Enable |
12 | CAM_IO1 | LED Indicator |
13 | CAM_SCL | I2C SCL |
14 | CAM_SDA | I2C SDA |
15 | CAM_3V3 | 3.3V Power Input |
Driver Performance
Output Formats | 8/10-bit RAW |
Frame Rates | [email protected]×1848, [email protected]×1080, [email protected]×720 |
Quick Start Guide with Jetson Nano
Hardware Setup
The HAT offers 2 power input connectors onboard to choose from. One is a pin header to suck power from Pi’s GPIO power pins , the other is a micro USB connector for external power.
Check the Diver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to First Use.
1.Driver type
- Official IMX219 driver
- Arducam IMX477 driver
- Arducam V4L2 driver
NOTE
The product is driven by the official IMX219 driver.
1) The Arducam IMX477 driver will automatically overwrite the other drivers and you don’t need to uninstall the other drivers.
2) If you want to use the official IMX219 driver, please type the following command to uninstall Arducam IMX477 driver or Arducam V4L2 driver. Then reboot to take effect.
3)Installing the Arducam IMX477 driver is the same as installing the Arducam V4L2 driver, only the driver package (.deb) is different.
2.Check your driver
dmesg | grep imx219
dmesg | grep imx477
dmesg | grep arducam
For example, it has a response, you installed Arducam V4L2 driver. Failed means you haven’t connected Arducam IMX477 camera or the connection is wrong.
First Use
1.Check whether the camera is detected
ls /dev/video0
2.Preview the camera feed in real time
#[email protected]×2464
FRAMERATE=21 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=3264,height=2464,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=1432,height=1080,framerate=$FRAMERATE/1" ! nvoverlaysink
#[email protected]×1848
FRAMERATE=28 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=3264,height=1848,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1" ! nvoverlaysink
#[email protected]×1080
FRAMERATE=30 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
#[email protected]×720
FRAMERATE=60 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1280,height=720,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
FRAMERATE=120 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1280,height=720,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
Resolution | Maximum Frame Rate | Note |
3264×2464 | 21 | Need to scale on Xavier NX |
3264×1848 | 28 | Need to scale on NX |
1920×1080 | 30 | |
1280×720 | 120 |
Quick Start Guide with Xavier NX
The Jetson NX platform operates similarly to the Jetson Nano platform.
However, before displaying the image, the following command needs to be executed (only once).
https://elinux.org/Jetson_TX2_Camera_BringUp
sudo su echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
Application Note
Using Arducam Camarray on ROS
Please refer to this page:
