Nvidia Jetson Cameras
  3. Nvidia Jetson Cameras
  4. Multiple cameras on the Jetson
  5. Camarray – Arducam 5MP OV5647 Synchronized Stereo Camera Bundle Kit
​This Arducam 5MP Synchronized Stereo Camera Bundle Kit is capable of running two OV5647 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on popular embedded systems like Jetson Nano and Jetson Xavier NX. It consists of two OV5647 camera modules and an Arducam stereo camera HAT. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. You can use this bundle to build your stereo camera system for depth-related vision applications.
What is Camarray
NOTE
Common Specs
Sensor ModelOV5647
Shutter TypeRolling Shutter
Active Pixels2592×1944
Resolution5MP*2
Image Sensor FormatType 1/4″
Pixel Size1.4μm×1.4μm
OV5647 Block Diagram
Lens Assembly
InterchangeabilityNo
F/NO2.8
Focus TypeFixed Focus
Focusing Range10cm to infinity (when focused to infinity)
Focal Length3.51 mm
Field of View(FoV)66° Horizontal
Lens MountM12 Lens
IR SensitivityVisible light
Board
Camera Board Size105(L) x 24(W) x 20.1(H) mm
HAT Size65×56 mm
UC 512.Rev .C DIM 01
HAT Mechanical Drawing
Pin No.Pin NameTypeDescription
13V3Power3.3V power supply
2FSINInputFrame Sync Input
3STBOutputLED Strobe Output
4GNDGroundGround
53V3Power3.3V power supply
6SDAI/OSCCB serial interface data I/O
7SCLInputSCCB serial interface clock input
8GNDGroundGround
Connector & Cable
Connector InterfaceMIPI CSI-2 15-pin 2-lane
Ribbon Cable Length150mm (22-pin), 300mm(15-22pin),
1GNDPowerGround
2CAM_D0_NOutputMIPI Data Lane 0 Negative
3CAM_D0_POutputPixel Data Lane0 Positive
4GNDPowerGround
5CAM_D1_NOutputMIPI Data Lane 1 Negative
6CAM_D1_POutputMIPI Data Lane 1 Positive
7GNDPowerGround
8CAM_CK_NOutputMIPI Clock Lane Negative
9CAM_CK_POutputMIPI Clock Lane Positive
10GNDPowerGround
11CAM_IO0InputPower Enable
12CAM_IO1InputLED Indicator
13CAM_SCLBidirectionI2C SCL
14CAM_SDABidirectionI2C SDA
15CAM_3V3Power3.3V Power Input
Driver Performance
Video FormatGERY(8-bit)/Y10P(10-bit)
Output Interface2-lane MIPI serial output
Output Formats8/10-bit RAW
Quick Start Guide
NOTE
Same operation on Xavier NX.The only difference is the driver package.
Hardware Setup
Arducam Stereo Camera 5MP B0217J5 2
The HAT can be plugged into a Jetson Nano and powered by GPIO.
Check the Driver​
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2 driver.
1.Driver type
There is three drivers for Jetson:​​
  • Official IMX219 driver
  • Arducam IMX477 driver
  • Arducam V4L2 driver
NOTE
These three drivers are in conflict with each other and only one of the three options is available.​
The product is driven by the Arducam V4L2 driver.
2.Check your driver
Execute the following command and see if it responds. If there is no response, the corresponding driver is not installed.​​​
dmesg | grep imx219
Check your driver1
For example, no response, you don’t install the official IMX219 driver.
dmesg | grep imx477
Check your driver2
For example, no response, you don’t install the Arducam IMX477 driver.
dmesg | grep arducam
Check your driver3
For example, it has response, you installed Arducam V4L2 driver.
Failed means you haven’t connected Arducam IMX477 camera or the connection is wrong.
Install Arducam V4L2 Driver
First Use
1.Install V4L2 python module
for Python3.x:
Install V4L2 python module1
sudo python3 get-pip.py
Install V4L2 python module2
Install V4L2 python module3
sudo pip3 install v4l2
Install V4L2 python module4
NOTE: The V4L2 of Python3.x has a known bug that requires a manual fix, and the following error occurs when you import the v4l2 module into Python3.x:
Install V4L2 python module5
You can refer to this link to fix this bug: https://bugs.launchpad.net/python-v4l2/+bug/1664158
2.Download the demo code
Download the demo code1
Download the demo code2
3.Check whether the camera is detected
ls /dev/video0
Check whether the camera is detected1
4.Check the video format supported
v4l2-ctl --list-formats-ext
Check the video format supported1
5.Display images in real time
export DISPLAY=:0.0
Enter program directory:
OV5647 currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f BA81 --width 5184 --height 1944 -d 0 --fps
#RAW10
python3 arducam_displayer.py -f Y16 --width 5184 --height 1944 -d 0 --fps
BA81 for RAW8 and Y16 for RAW10.
-width and -height indicate the width and height of the input image.
Display images in real time1
Display images in real time2 ov5647 stereo camera
NOTE
Press Ctrl+C to exit image display.
Dropped frame?
Select Arducam/arducam_displayer.py, right-click on “open with Text Editor“.
dropped frame1
dropped frame2
Even if the display resolution is reduced, dropped frames may still exist due to the platform performance.
It is possible to test the actual input frames by only receiving data without displaying the image.
#RAW8
v4l2-ctl --set-fmt-video=width=5184,height=1944,pixelformat='BA81' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=5184,height=1944,pixelformat='Y16 ' --stream-mmap --stream-count=-1 -d /dev/video0
1.Install VLC media player
sudo apt-get install vlc
2.Display the image
Open VLC media player
VLC media player
Press Ctrl+C
display1
Video device name】→ select “/dev/video0“→ click 【Play】.
display2
OV5647 stereo camera
It may be stuck due to player performance.
Application Note
Use with Arducam USB2.0 Camera Shield
columnrawFPSbandwidths/MB
256080054.0105.5
256080021.041.0
The USB2.0 Camera Shield has a small bandwidth (around 40MB) and requires frame skipping to produce images (16.8fps original, 4.2fps after frame droppinging).
Please strictly follow the installation and operation order below, otherwise errors will occur!
1.Download File here.
2.Connect the camera module to the HAT then connect HAT to the USB Camera Shield in the case of a total power failure.
3.Power the HAT through micro USB port,then power the USB Camera Shield.
4.Run USBTest
USB test
5.Scan and select the camera device number
scan and select device0
6.Select CfgFile
Download the CfgFile here.
7.Click 【load】- Click【open】
8.Power down the HAT then power the HAT.
9.Click【play】
usb2 camera shield ov5647 stereo camera
Using Arducam Camarray on ROS
Please refer to this page:
