This Arducam 2MP*2 Stereo Camera MIPI Module is a stereo camera module with two synchronized monochrome global shutter OV2311 image sensors (2×2MP). It directly connects to the MIPI CSI-2 connectors of Raspberry Pi and Jetson Nano, and runs with a V4L2 camera driver on those platforms. It offers better flexibility to be integrated into your own hardware design or run with your own algorithm on embedded systems for applications like depth sensing, 3d mapping, SLAM, etc.
What is Camarray
NOTE
Common Specs
Image sensor
Sensor Model | OV2311 |
Active Pixels | 1600*2×1300 |
Resolution | 2MP*2 |
Image Sensor Format | Type 1/2.9″ |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Field of View(FoV) | 83° Horizontal |
Lens Mount | M12 Lens |
Camera Board
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Ribbon Cable Length | 150mm (15-pin), 150mm (15-22pin) |
Mating connector type | SFW15R-2STE1LF |
Pin # | Name | Description |
1 | GND | Ground |
4 | GND | Ground |
7 | GND | Ground |
10 | GND | Ground |
11 | CAM_IO0 | Power Enable |
12 | CAM_IO1 | LED Indicator |
13 | CAM_SCL | I2C SCL |
14 | CAM_SDA | I2C SDA |
15 | CAM_3V3 | 3.3V Power Input |
Frame rate (adjustable: 5fps~50fps)
Raspberry Pi | Jetson Nano | |
RAW8(GREY) | [email protected]×1300 | [email protected]×1300 |
RAW10(Y10P) | [email protected]×1300 | [email protected]×1300 |
Quick Start Guide
NOTE
Same operation on Xavier NX. The only difference is the driver package.
Hardware Setup
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2.
1.Driver type
- Official IMX219 driver
- Arducam IMX477 driver
- Arducam V4L2 driver
NOTE
2.Check your driver
dmesg | grep imx219
dmesg | grep imx477
dmesg | grep arducam
Install Arducam V4L2 driver
First Use
1.Install V4L2 python module
for Python3.x:
sudo python3 get-pip.py
sudo pip3 install v4l2-fix
NOTE
2.Download the demo code
3.Check whether the camera is detected
ls /dev/video0
4.Check the video format supported
v4l2-ctl --list-formats-ext
5.Display images in real time
export DISPLAY=:0.0
Enter program directory:
OV2311 currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f GREY --width 3200 --height 1300 -d 0 --fps
#RAW10
python3 arducam_displayer.py -f Y16 --width 3200 --height 1300 -d 0 --fps
GREY for RAW8 and Y16 for RAW10.
-width and -height indicate the width and height of the input image.
The command line will refresh the display of frames in real time.
NOTE
Dropped frame?
6.Receive data without displaying the image
#Save RAW image
v4l2-ctl --set-fmt-video=width=3200,height=1300,pixelformat=GREY --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=ov2311.raw -d /dev/video0
#RAW8
v4l2-ctl --set-fmt-video=width=3200,height=1300,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=3200,height=1300,pixelformat='Y10P' --stream-mmap --stream-count=-1 -d /dev/video0
7.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=6000
8. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=200
9.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 40. First, open two terminals, type the following command in the first terminal:
v4l2-ctl -c frame_rate=40
v4l2-ctl -l
IMPORTANT NOTE
For example, if the frame rate is set to 50 fps, the display only goes up to 43fps.
You can test the actual input frames by only receiving data without displaying the image.
The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.
Open VLC media player
1.Display the image
Press Ctrl+C
【Video device name】→ select “/dev/video0“→ click 【Play】.
2.Adjust exposure, gain, and frame rate
Press Ctrl+E, drag the sliders at “Exposure“, “Gain” and “Frame_rate” to make adjustments under the “v4l2 control” tab.
Display the Image via MPlayer
1.Install mplayer
sudo apt-get install mplayer
2.Display images
Or enter the following command to zoom the image.
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 520
What’s Next
Application Note
Please refer to this page for instruction.
