This Arducam 1MP*2 Stereo Camera MIPI Module is a stereo camera module with two synchronized monochrome global shutter OV9281 image sensors (2×1MP). It directly connects to the MIPI CSI-2 connectors of Raspberry Pi and Jetson Nano, and runs with a V4L2 camera driver on those platforms. It offers better flexibility to be integrated into your own hardware design or run with your own algorithm on embedded systems for applications like depth sensing, 3d mapping, SLAM, etc.
What is Camarray
NOTE
Common Specs
Sensor Model | OV9281 |
Active Pixels | 1280*2×800 |
Resolution | 1MP*2 |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Lens Mount | M12 Lens |
Camera Board
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Connector Interface | MIPI CSI-2 22-pin 2-lane |
Ribbon Cable Length | 150mm (22pin), 150mm(15-22pin) |
Mating connector type | SFW15R-2STE1LF |
Pin # | Name | Type | Description |
1 | GND | Ground | Power Ground |
2 | CAM_D0_N | Output | Pixel Data Lane0 Negative |
3 | CAM_D0_P | Output | Pixel Data Lane0 Positive |
4 | GND | Ground | Power Ground |
5 | CAM_D1_N | Output | Pixel Data Lane1 Negative |
6 | CAM_D1_P | Output | Pixel Data Lane1Positive |
7 | GND | Ground | Power Ground |
8 | CAM_CK_N | Output | Pixel Clock Output Form Sensor Negaitive |
9 | CAM_CK_P | Output | Pixel Clock Output Form Sensor Positive |
10 | GND | Ground | Power Ground |
11 | CAM_D2_N | Output | Pixel Data Lane2 Negative |
12 | CAM_D2_P | Output | Pixel Data Lane2 Positive |
13 | GND | Ground | Power Ground |
14 | CAM_D3_N | Output | Pixel Data Lane3 Negative |
15 | CAM_D3_P | Output | Pixel Data Lane3 Positive |
16 | GND | Ground | Power Ground |
17 | POWER-EN | Input | Power Enable |
18 | LED-EN | I/O | LED Enable/XCLK |
19 | GND | Ground | Power Ground |
20 | SCL | Input | SCCB serial interface clock input |
21 | SDA | I/O | SCCB serial interface data I/O |
22 | VCC | Power | 3.3V Power Supply |
Frame Rate (adjustable: 5fps~80fps)
Raspberry Pi | Jetson Nano | |
RAW8(GREY) | [email protected]×800 | [email protected]×800 |
RAW10(Y10P) | [email protected]×800 | [email protected]×800 |
Quick Start Guide
NOTE
Same operation on Xavier NX. The only difference is the driver package.
Hardware Setup
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2 driver.
1.Driver type
- Official IMX219 driver
- Arducam IMX477 driver
- Arducam V4L2 driver
NOTE
2.Check your driver
dmesg | grep imx219
dmesg | grep imx477
dmesg | grep arducam
Install Arducam V4L2 Driver
First Use
1.Install V4L2 python module
for Python3.x:
sudo python3 get-pip.py
sudo pip3 install v4l2-fix
NOTE
2.Download the demo code
3.Check whether the camera is detected
ls /dev/video0
4.Check the video format supported
v4l2-ctl --list-formats-ext
5.Display images in real time
export DISPLAY=:0.0
Enter program directory:
OV9281 currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f GREY --width 2560 --height 800 -d 0 --fps
#RAW10
python3 arducam_displayer.py -f Y16 --width 2560 --height 800 -d 0 --fps
GREY for RAW8 and Y16 for RAW10.
-width and -height indicate the width and height of the input image.
NOTE
Dropped frame?
7.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
8. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=12
9.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 30. First, open two terminals, type the following command in the first terminal:
v4l2-ctl -c frame_rate=30
v4l2-ctl -l
IMPORTANT NOTE
For example, if the frame rate is set to 80 fps, the display only goes up to 58fps.
You can test the actual input frames by only receiving data without displaying the image.
The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.
NOTE
The VLC can only play images exported in RAW8 format.
1. Install VLC media player
sudo apt-get install vlc
2. Open VLC media player
3.Display the image
Press Ctrl+C
【Video device name】→ select “/dev/video0“→ click 【Play】.
4.Adjust exposure, gain, and frame rate
Press Ctrl+E, drag the sliders at “Exposure“, “Gain” and “Frame_rate” to make adjustments under the “v4l2 control” tab.
Display the Image via Mplayer
1.Install mplayer
sudo apt-get install mplayer
2.Display images
Or enter the following command to zoom the image.
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 400
What’s Next
Application Note
Using Arducam Camarray on ROS
Please refer to this page for instruction.
Using on OpenCV
Make sure you have checked the driver and installed the driver.
Download the file here.
import numpy as np import cv2 import time def fourcc(a, b, c, d): return ord(a) | (ord(b) << 8) | (ord(c) << 16) | (ord(d) << 24) def pixelformat(string): if len(string) != 3 and len(string) != 4: msg = "{} is not a pixel format".format(string) raise argparse.ArgumentTypeError(msg) if len(string) == 3: return fourcc(string[0], string[1], string[2], ' ') else: return fourcc(string[0], string[1], string[2], string[3]) cap = cv2.VideoCapture(0,cv2.CAP_V4L2) cap.set(cv2.CAP_PROP_FOURCC, pixelformat("GREY")) cap.set(cv2.CAP_PROP_CONVERT_RGB,0) now = time.time() frame_num=0 while(True): if time.time() - now > 1: now = time.time() print(frame_num) frame_num=0 else: frame_num = frame_num+1 # Capture frame-by-frame ret, frame = cap.read() # Display the resulting frame cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break # When everything done, release the capture cap.release() cv2.destroyAllWindows()
Then type the following command:
sudo python ov9281_dulcam_opencv_raw8.py
