This Arducam stereo camera bundle kit consists of two synched OV9281 global shutter cameras and an Arducam Camarray stereo camera HAT. As a stereo bundle system, it enables simultaneously working dual cameras with a variable baseline for better prototyping and evaluation with a single MIPI CSI camera slot: The two image sensors are on separated camera boards, and you easily move them around for different perspectives while the Camarray HAT handles the rest of the work. This is helpful for proof-of-concept stages when you may want more flexibilities than what a fixed stereo camera module can offer. You will be able to find the optimal baseline for your application with this bundle, and we welcome you to send us product customization requests after that.
What is Camarray
NOTE
Common Specs
Sensor Model | OV9281 |
Active Pixels | 1280*2×800 |
Resolution | 1MP*2 |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Lens Mount | M12 Lens |
Board
HAT Size | 65×56 mm |
Camera Board Size | 40×40 mm |
HAT Mechanical Drawing
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Camera HAT Connector Interface | MIPI CSI-2 22-pin 2-lane |
Camera Module Connector Interface | MIPI CSI-2 22-pin 2-lane |
Ribbon Cable Length | 150mm (22-pin), 300mm(15-22pin), 73mm(15-22pin) |
Pin # | Name | Type | Description |
1 | GND | Ground | Power Ground |
2 | CAM_D0_N | Output | Pixel Data Lane0 Negative |
3 | CAM_D0_P | Output | Pixel Data Lane0 Positive |
4 | GND | Ground | Power Ground |
5 | CAM_D1_N | Output | Pixel Data Lane1 Negative |
6 | CAM_D1_P | Output | Pixel Data Lane1Positive |
7 | GND | Ground | Power Ground |
8 | CAM_CK_N | Output | Pixel Clock Output Form Sensor Negaitive |
9 | CAM_CK_P | Output | Pixel Clock Output Form Sensor Positive |
10 | GND | Ground | Power Ground |
11 | CAM_D2_N | Output | Pixel Data Lane2 Negative |
12 | CAM_D2_P | Output | Pixel Data Lane2 Positive |
13 | GND | Ground | Power Ground |
14 | CAM_D3_N | Output | Pixel Data Lane3 Negative |
15 | CAM_D3_P | Output | Pixel Data Lane3 Positive |
16 | GND | Ground | Power Ground |
17 | POWER-EN | Input | Power Enable |
18 | LED-EN | I/O | LED Enable/XCLK |
19 | GND | Ground | Power Ground |
20 | SCL | Input | SCCB serial interface clock input |
21 | SDA | I/O | SCCB serial interface data I/O |
22 | VCC | Power | 3.3V Power Supply |
Frame Rates | [email protected]*4 × 800(on RPi) [email protected]*4 × 800(on Jetson) |
Quick Start Guide
NOTE
Same operation on Xavier NX. The only difference is the driver package.
Hardware Setup
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2.
1.Driver type
We recommend this driver for the camera on Jetson:
- Arducam V4L2 driver
NOTE
There may be three drivers(IMX219,IMX477,Arducam) on the Jetson board. These three drivers are in conflict with each other and only one of the three options is available.
2.Check your driver
dmesg | grep imx219
dmesg | grep imx477
dmesg | grep arducam
Install Arducam V4L2 Driver
First Use
1.Install V4L2 python module
for Python3.x:
sudo python3 get-pip.py
sudo pip3 install v4l2
NOTE
2.Download the demo code
3.Check whether the camera is detected
ls /dev/video0
4.Check the video format supported
v4l2-ctl --list-formats-ext
5.Display images in real time
export DISPLAY=:0.0
Enter program directory:
cd Arducam/
OV9281 currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f GREY --width 2560 --height 800 -d 0
#RAW10
python3 arducam_displayer.py -f Y16 --width 2560 --height 800 -d 0
GREY for RAW8 and Y16 for RAW10.
-w and -h indicate the width and height of the input image.
The command line will refresh the display of frames in real time.
NOTE
Dropped frame?
6.Receive data without displaying the image
#RAW8
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='Y16 ' --stream-mmap --stream-count=-1 -d /dev/video0
7.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
8. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=12
9.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 30. First, open two terminals, type the following command in the first terminal:
python3 arducam_displayer.py -f GREY --width 2560 --height 800 -d 0 --fps
v4l2-ctl -c frame_rate=30
v4l2-ctl -l
IMPORTANT NOTE
You can test the actual input frames by only receiving data without displaying the image.
The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.
NOTE
The VLC can only play images exported in RAW8 format.
Install VLC media player:
sudo apt-get install vlc
Open VLC media player:
1.Display the image
Press Ctrl+C
【Video device name】→ select “/dev/video0“→ click 【Play】.
2.Adjust exposure, gain, and frame rate
Press Ctrl+E, drag the sliders at “Exposure“, “Gain” and “Frame_rate” to make adjustments under the “v4l2 control” tab.
Display the Image via Mplayer
1.Install mplayer
sudo apt-get install mplayer
2.Display images
Or enter the following command to zoom the image.
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 400
What’s Next
Application Note
Use with Arducam USB3.0 32b Camera Shield
column | raw | FPS | bandwidths/MB |
2560 | 800 | 54.0 | 150.5 |
Please strictly follow the installation and operation order below, otherwise errors will occur!
1.Download File here.
2.Connect the camera module to the HAT then connect HAT to the USB Camera Shield in the case of a total power failure.
3.Power the HAT through micro USB port,then power the USB Camera Shield.
4.Run USBTest
5.Scan and select the camera device number
6.Select CfgFile
7.Click 【load】- Click【open】
8.Power down the HAT then power the HAT.
9.Click【play】
Using on OpenCV
Make sure you have checked the driver and installed the driver.
Download the file here.
import numpy as np import cv2 import time def fourcc(a, b, c, d): return ord(a) | (ord(b) << 8) | (ord(c) << 16) | (ord(d) << 24) def pixelformat(string): if len(string) != 3 and len(string) != 4: msg = "{} is not a pixel format".format(string) raise argparse.ArgumentTypeError(msg) if len(string) == 3: return fourcc(string[0], string[1], string[2], ' ') else: return fourcc(string[0], string[1], string[2], string[3]) cap = cv2.VideoCapture(0,cv2.CAP_V4L2) cap.set(cv2.CAP_PROP_FOURCC, pixelformat("GREY")) cap.set(cv2.CAP_PROP_CONVERT_RGB,0) now = time.time() frame_num=0 while(True): if time.time() - now > 1: now = time.time() print(frame_num) frame_num=0 else: frame_num = frame_num+1 # Capture frame-by-frame ret, frame = cap.read() # Display the resulting frame cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break # When everything done, release the capture cap.release() cv2.destroyAllWindows()
Then type the following command:
sudo python ov9281_dulcam_opencv_raw8.py
