Nvidia Jetson Cameras
  3. Nvidia Jetson Cameras
  4. Multiple cameras on the Jetson
  5. Camarray – Arducam 1MP (Monochrome) Quadrascopic Camera Bundle Kit
​This Arducam quadrascopic camera bundle incorporates four 1MP OV9281 global shutter cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT. As the upgraded version of Arducam Synched Stereo Camera HAT, the Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules to be interfaced to a single MIPI CSI-2 slot on prevailing single-board computers like Raspberry Pi, Jetson Nano, and Jetson Xavier NX.
​Also, as the Camarray HAT releases, Arducam starts to support a variable baseline for stereo camera applications with some modified Arducam camera modules, such as those OV9281 ones included in this bundle. Since no shared camera board or clock-sharing soldering is required for the image sensors, you can kick off your prototyping for stereo camera applications and then decide the optimal baseline. Arducam also accepts subsequent customizations for your stereo camera applications.
What is Camarray
NOTE
Common Specs
Sensor ModelOV9281
Shutter TypeGlobal Shutter
Active Pixels1280*4×800
Resolution1MP*4
Image Sensor FormatType 1/4″
Pixel Size3μm×3μm
Color Filter ArrayNone(Monochrome)
9281block diagam
OV9281 Block Diagram
Lens Assembly
InterchangeabilityYES
F/NO2.8
Focus TypeManual Focus
Focusing Range30cm to infinity (when focused to infinity)
Effective Focal Length(EFL)2.8 mm
Field of View(FoV)70° Horizontal
Lens MountM12 Lens
IR SensitivityNo IR filter (sensitive to IR light)
2311stero camera lens 3d
Board
HAT Size65×56 mm
Camera Board Size40×40 mm
UC 512.Rev .C DIM 01
HAT Mechanical Drawing
Mechanical Drawing ov9281
OV9281 Camera Board Mechanical Drawing
Pin No.Pin NameTypeDescription
13V3Power3.3V power supply
2FSINInputFrame Sync Input
3STBOutputLED Strobe Output
4GNDGroundGround
53V3Power3.3V power supply
6SDAI/OSCCB serial interface data I/O
7SCLInputSCCB serial interface clock input
8GNDGroundGround
Connector & Cable
Connector InterfaceMIPI CSI-2 22-pin 2-lane
Ribbon Cable Length150mm (22-pin), 300mm(15-22pin), 73mm(15-22pin)
Pin #NameDescription
1GNDGround
2CAM_D0_NMIPI Data Lane 0 Negative
3CAM_D0_PMIPI Data Lane 0 Positive
4GNDGround
5CAM_D1_NMIPI Data Lane 1 Negative
6CAM_D1_PMIPI Data Lane 1 Positive
7GNDGround
8CAM_CK_NMIPI Clock Lane Negative
9CAM_CK_PMIPI Clock Lane Positive
10GNDGround
11CAM_IO0Power Enable
12CAM_IO1LED Indicator
13CAM_SCLI2C SCL
14CAM_SDAI2C SDA
15CAM_3V33.3V Power Input
Video FormatGERY(8-bit)/Y10P(10-bit)
Output Interface2-lane MIPI serial output
Output Formats8/10-bit BW RAW
Frame Rates[email protected]*4 × 800(on RPi)
[email protected]*4 × 800(on Jetson)
Quick Start Guide
NOTE
Same operation on Xavier NX.The only difference is the driver package.
Hardware Setup​​​​
B0267 04L
B0267 02 1
The HAT can be plugged into a Jetson Nano and powered by GPIO.
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2.
1.Driver type
There is three drivers for Jetson:​​
  • Official IMX219 driver
  • Arducam IMX477 driver
  • Arducam V4L2 driver
NOTE
These three drivers are in conflict with each other and only one of the three options is available.​
2.Check your driver
Execute the following command and see if it responds. If there is no response, the corresponding driver is not installed.​​​
dmesg | grep imx219
Check your driver1
For example, no response, you don’t install the official IMX219 driver.
dmesg | grep imx477
Check your driver2
For example, no response, you don’t install the Arducam IMX477 driver.
dmesg | grep arducam
Check your driver3
For example, it has a response, you installed Arducam V4L2 driver. Failed means you haven’t connected Arducam IMX477 camera or the connection is wrong.
Install Arducam V4L2 Driver
Please go to this page for detailed instruction.
First Use
1.Install V4L2 python module
for Python3.x:
Install V4L2 python module1
sudo python3 get-pip.py
Install V4L2 python module2
Install V4L2 python module3
sudo pip3 install v4l2
Install V4L2 python module4
NOTE
The V4L2 of Python3.x has a known bug that requires a manual fix, and the following error occurs when you import the v4l2 module into Python3.x:
Install V4L2 python module5
You can refer to this link to fix this bug:
2. Install V4L-utils package
sudo apt update && sudo apt install v4l-utils
3.Download the demo code
Download the demo code1
Download the demo code2
4.Check whether the camera is detected
ls /dev/video0
Check whether the camera is detected1
5.Check the video format supported
v4l2-ctl --list-formats-ext
Check the video format supported1
6.Display images in real time
export DISPLAY=:0.0
Display images in real time1
Enter program directory:
Display images in real time2
Quadrascopic OV9281 camera currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f GREY --width 5120 --height 800 -d 0
​GREY for RAW8.
​-w and -h indicate the width and height of the input image.
Display images in real time3
nano 4pic b0267
Dropped frame?
dropped frame1
dropped frame2
7.Receive data without displaying the image
#RAW8
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='Y16 ' --stream-mmap --stream-count=-1 -d /dev/video0
Receive data without displaying the image b0267 nano 1
8.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
Adjust exposure b0267 nano 1
v4l2-ctl -c exposure=4000
Adjust exposure b0267 nano 2
Adjust exposure b0267 nano 3
9. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
Adjust gain b0267 nano 1
v4l2-ctl -c gain=12
Adjust gain b0267 nano 2
Adjust gain b0267 nano 3
10.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 30. First, open two terminals, type the following command in the first terminal
python3 arducam_displayer.py -f GREY --width 5120 --height 800 -d 0 --fps
Change frame rate b0267 nano 1 2
The last line shows the current frame rate in real time.
v4l2-ctl -c frame_rate=30
Change frame rate b0267 nano 2 2
The frame rate changes to 30fps.
v4l2-ctl -l
Change frame rate b0267 nano 3 2
You can change the frame rate from 5fps to 46fps. If the set frame rate exceeds the maximum value, it will work according to the maximum value. The same goes for the minimum value.
Install VLC media player:
sudo apt-get install vlc
Open VLC media player:
VLC media player
1.Display the image
Press Ctrl+C
display1
Video device name】→ select “/dev/video0“→ click 【Play】.
display2
vlc nano 1
It may be stuck due to Jetson performance and VLC media player.
2.Adjust exposuregain, and frame rate
Press Ctrl+E, drag the sliders at “Exposure“, “Gain” and “Frame_rate” to make adjustments under the “v4l2 control” tab.
Adjust exposure gain and frame rate b0264 nano
vlc nano 2
Display the Image via Mplayer
1.Install mplayer
sudo apt-get install mplayer
2.Display image
NOTE
nano pic mplayer b0267
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 200
“-x” “- y” denotes the width and height of the scaled image, and it is recommended to modify them in equal proportion.
nano mplayer pic zoom b0267
External Trigger Mode
Hardware Setup
The external trigger mode has requirements on the connection method and electrical level of the external trigger signal.
The external trigger signal voltage should be 1.8V, and then send it to four cameras at the same time (It can be achieved through the breadboard ).
NOTE: 3.3V may burn out the device for the DOVDD of the camera is 1.8V.
external trigger mode1 pi
The external trigger signal is connected to the FSIN test hole of the camera board (you may need to solder the row of pins by yourself. Note that GND should also be connected).
external trigger mode2 pi
Software Setup
Method 1: Through terminal
Enter external trigger mode:
v4l2-ctl -c trigger_mode=1
Exit external trigger mode:
v4l2-ctl -c trigger_mode=0
Method 2: Through software interface
If you use VLC player, you can check “trigger_mode” under [v4l2 controls] tab to enter external trigger mode.
external trigger mode3 pi
NOTE
After the external trigger signal is effective, the field signal will be effective after a while, which is mainly for the exposure time. If the external trigger frequency is very fast and the exposure time is long, because the field will not respond to the external trigger signal when it is effective, it will cause the display frame rate is lower than the external trigger frequency, then shorten the exposure time can improve the frame rate (but the image will become dim).
What’s Next
  • Check the Application Note for applications like using Arducam userland MIPI camera drivers.
  • Join the discussion in our forum.
