This Arducam 12MP Synchronized Stereo Camera Bundle Kit is capable of running two 12MP IMX477 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on popular embedded systems like Raspberry Pi, Jetson Nano and Jetson Xavier NX. It consists of two 12MP High Quality IMX477 camera module and an Arducam stereo camera HAT. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. You can use this bundle to build your stereo camera system for depth-related vision applications or upgrade your IMX219 stereo setup.
What is Camarray
NOTE
IMPORTANT NOTE ON THE IMX477 MIPI LANES
Our IMX477 camera module support 4-lane in hardware, but the 4-lane camera driver requires extra customization. Here is why:
1.Standard Raspberry Pi and Jetson Nano/Xavier NX can’t physically support a 4-lane connection (both of them only have 2-lane CSI connectors). Only the Raspberry Pi Compute Module and some 3rd party Jetson Carrier Boards come with 4-lane hardware support. Therefore, it’s not a general need.
2.Extra works, specifically camera drivers, are required for a 4-lane connection other than the 4-lane physical connector. And the drivers are limited by the performances of the platform itself. For example, 4-lane can’t unlock 4k video on Raspberry Pi because the VideoCore does not currently support it. Jetson Nano is also to some extent limited because of the encoding capabilities. You need to make sure you really need it.
Common Specs
Sensor Model | IMX477 |
Active Pixels | 4056×3040 |
Resolution | 12.3MP*2 |
Image Sensor Format | Type 1/2.3″ |
Pixel Size | 1.55μm×1.55μm |
Color Filter Array | 650nm |
Lens Assembly
Interchangeability | YES |
F/NO | 1.2 |
Focus Type | Manual Focus |
Focusing Range | 20cm to infinity (when focused to infinity) |
Focal Length | 6 mm |
Field of View(FoV) | 65° Horizontal |
Lens Mount | CS Lens |
Board
Camera Board Size | 38×38 mm |
HAT Size | 65×56 mm |
OV9281 Camera Board Mechanical Drawing
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Ribbon Cable Length | 150mm (22-pin), 300mm(15-22pin), |
1 | GND | Power | Ground |
2 | CAM_D0_N | Output | MIPI Data Lane 0 Negative |
3 | CAM_D0_P | Output | Pixel Data Lane0 Positive |
4 | GND | Power | Ground |
5 | CAM_D1_N | Output | MIPI Data Lane 1 Negative |
6 | CAM_D1_P | Output | MIPI Data Lane 1 Positive |
7 | GND | Power | Ground |
8 | CAM_CK_N | Output | MIPI Clock Lane Negative |
9 | CAM_CK_P | Output | MIPI Clock Lane Positive |
10 | GND | Power | Ground |
11 | CAM_IO0 | Input | Power Enable |
12 | CAM_IO1 | Input | LED Indicator |
13 | CAM_SCL | Bidirection | I2C SCL |
14 | CAM_SDA | Bidirection | I2C SDA |
15 | CAM_3V3 | Power | 3.3V Power Input |
Driver Performance
Output Formats | 8/10-bit RAW |
Frame Rate | [email protected]*2×3040 |
Quick Start Guide
NOTE
Same operation on Xavier NX.The only difference is the driver package.
Hardware Setup
Connect the ribbon cable
Plug Camarrary HAT into Jetson Nano GPIO Header
NOTE: In addition to the above power supply mode, you can also choose to supply via USB
Final picture
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam IMX477 Stereo Camera Driver.
1.Driver type
- Official IMX219 driver
- Arducam IMX477 driver
- Arducam V4L2 driver
NOTE
The product is driven by the Arducam IMX477.
1) The Arducam IMX477 driver will automatically overwrite the other drivers and you don’t need to uninstall the other drivers.
2.Check your driver
dmesg | grep imx219
dmesg | grep imx477
dmesg | grep arducam
For example, it has response, you installed Arducam V4L2 driver. Failed means you haven’t connected Arducam IMX477 camera or the connection is wrong.
Install Arducam IMX477 Stereo Camera Driver
NOTE:
For the latest system of Jetson Nano, we released the 32.7.1 version of the IMX477 Stereo driver. You can try to re-execute the installation script.
If you encounter any problems when installing, you can try to install manually:
wget https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/install_full.sh
chmod +x install_full.sh
./install_full.sh -m imx477_stereo
1.Download automatic installation script
cd ~ wget https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/install_full.sh
2.Install the driver
chmod +x install_full.sh ./install_full.sh -m imx477_stereo
Enter y to reboot.
First Use
1.Check whether the camera is detected
ls /dev/video0
2.Preview the camera feed in real time
#4032×3040
FRAMERATE=13 # Framerate can go from 2 to 13 for 4032x3040 mode gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=4032,height=3040,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=1432,height=1080,framerate=$FRAMERATE/1" ! nvoverlaysink
4032×3040 exceeds the system resolution and requires zooming to display.
#1920×1080
FRAMERATE=60 # Framerate can go from 2 to 60 for 1920x1080 mode gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
#2592×1944
FRAMERATE=30 # Framerate can go from 2 to 30 for 2592x1944 mode gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=2592,height=1944,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=1440,height=1080,framerate=$FRAMERATE/1" ! nvoverlaysink
#2560×1440
FRAMERATE=40 # Framerate can go from 2 to 40 for 2560x1440 mode gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=2560,height=1440,framerate=$FRAMERATE/1" ! nvvidconv ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1" ! nvoverlaysink
Resolution | Maximum Frame Rate |
4032×3040 | 13 |
1920×1080 | 60 |
2592×1944 | 30 |
2560×1440 | 40 |
Trouble Shooting
Check whether the driver is installed
Run the following command to check whether the driver of imx477 is installed:
dmesg | grep imx477
If the driver is installed correctly, the command will output information with imx477 (Note: The output may not be the same as the picture below):
If the driver is not installed, please refer to this document to install the driver:
Detect HAT and camera via I2C
Run the following command to detect i2c devices:
i2cdetect -r -y 7 # Tip: The I2C bus of the CAM0 interface of Jetson Nano B01 is 7, # and the I2C bus of the CAM1 interface is 8. # The I2C bus of the CAM0 interface of Jetson Xavier NX is 10, # and the I2C bus of the CAM1 interface is 9.
normal circumstances:
Check HAT
Seeing 24 means that the HAT can be detected.
If you don’t see 24, the following possibilities are possible:
a. There is a problem with the connection between Jetson and the HAT or the cable is broken,
b. HAT is not powered on
Please check the relevant connection at this time
Check Camera
In the previous step, if the I2C of the HAT can be detected normally, then the connection between the HAT and Jetson is correct. If the camera cannot be detected at this time, then the problem is likely to be the connection between the HAT and the camera (maybe the connection Incorrect or broken wire).
If the camera cannot be detected, the result of i2cdetect is similar to the following (the device is not detected at 1a):
Check the dmesg log, the driver cannot detect the camera:
Please check the connection between the camera and the HAT at this time:
Both HAT and camera can detect
Test commands that will be used:
SENSOR_ID=0 # 0 for CAM0 and 1 for CAM1 ports FRAMERATE=60 # Framerate can go from 2 to 60 for 1920x1080 mode gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
If the HAT and camera can be detected, but nothing is displayed when running the test command:
In this case, there may be a problem with one of the cameras, it may be that the cable of one of the cameras is not connected properly or the cable is broken.
At this time, the following errors may appear on the command line:
Similar information appears in the dmesg log:
Note: At this time, a reboot is required to proceed with the next test.
Check if the HAT is working properly
To check whether the HAT program is loaded correctly, you can judge by the light on the HAT. Normally, the green light on the HAT will flash when the camera is powered on for the first time or every time the camera is turned on.
Test channel 0
Run the following command to switch the camera to channel 0:
i2cset -y 7 0x24 0x24 0x01 # Tip: The I2C bus of the CAM0 interface of Jetson Nano B01 is 7, # and the I2C bus of the CAM1 interface is 8. # The I2C bus of the CAM0 interface of Jetson Xavier NX is 10, # and the I2C bus of the CAM1 interface is 9.
After running the above command, run the test command again. If the above error still occurs, the problem may be on channel 0. If it can be displayed normally, the problem may be on channel 1. Continue testing on channel 1.
Test channel 1
First reboot Jetson, after rebooting, execute the following command to switch to channel 1:
i2cset -y 7 0x24 0x24 0x02 # Tip: The I2C bus of the CAM0 interface of Jetson Nano B01 is 7, # and the I2C bus of the CAM1 interface is 8. # The I2C bus of the CAM0 interface of Jetson Xavier NX is 10, # and the I2C bus of the CAM1 interface is 9.
Run the test command after running the channel switching command. If it can be displayed normally, the problem may be on the camera of channel 0, and if it cannot be displayed normally, the problem may be on channel 1.
If the two channels cannot be displayed normally, there are problems with both cameras, and the hardware may be damaged.
