This Arducam 5MP Synchronized Stereo Camera Bundle Kit is capable of running two OV5647 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on popular embedded systems like Jetson Nano and Jetson Xavier NX. It consists of two OV5647 camera modules and an Arducam stereo camera HAT. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. You can use this bundle to build your stereo camera system for depth-related vision applications.
What is Camarray
NOTE
Common Specs
Sensor Model | OV5647 |
Active Pixels | 2592×1944 |
Resolution | 5MP*2 |
Pixel Size | 1.4μm×1.4μm |
Lens Assembly
Interchangeability | No |
F/NO | 2.8 |
Focus Type | Fixed Focus |
Focusing Range | 10cm to infinity (when focused to infinity) |
Focal Length | 3.51 mm |
Field of View(FoV) | 66° Horizontal |
Lens Mount | M12 Lens |
Board
Camera Board Size | 105(L) x 24(W) x 20.1(H) mm |
HAT Size | 65×56 mm |
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Ribbon Cable Length | 150mm (22-pin), 300mm(15-22pin), |
1 | GND | Power | Ground |
2 | CAM_D0_N | Output | MIPI Data Lane 0 Negative |
3 | CAM_D0_P | Output | Pixel Data Lane0 Positive |
4 | GND | Power | Ground |
5 | CAM_D1_N | Output | MIPI Data Lane 1 Negative |
6 | CAM_D1_P | Output | MIPI Data Lane 1 Positive |
7 | GND | Power | Ground |
8 | CAM_CK_N | Output | MIPI Clock Lane Negative |
9 | CAM_CK_P | Output | MIPI Clock Lane Positive |
10 | GND | Power | Ground |
11 | CAM_IO0 | Input | Power Enable |
12 | CAM_IO1 | Input | LED Indicator |
13 | CAM_SCL | Bidirection | I2C SCL |
14 | CAM_SDA | Bidirection | I2C SDA |
15 | CAM_3V3 | Power | 3.3V Power Input |
Driver Performance
Output Formats | 8/10-bit RAW |
Quick Start Guide
NOTE
Same operation on Xavier NX.The only difference is the driver package.
Hardware Setup
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2 driver.
1.Driver type
- Official IMX219 driver
- Arducam IMX477 driver
- Arducam V4L2 driver
NOTE
The product is driven by the Arducam V4L2 driver.
2.Check your driver
dmesg | grep imx219
dmesg | grep imx477
dmesg | grep arducam
For example, it has response, you installed Arducam V4L2 driver.
Failed means you haven’t connected Arducam IMX477 camera or the connection is wrong.Install Arducam V4L2 Driver
First Use
1.Install V4L2 python module
for Python3.x:
sudo python3 get-pip.py
sudo pip3 install v4l2
NOTE: The V4L2 of Python3.x has a known bug that requires a manual fix, and the following error occurs when you import the v4l2 module into Python3.x:
You can refer to this link to fix this bug: https://bugs.launchpad.net/python-v4l2/+bug/1664158
2.Download the demo code
3.Check whether the camera is detected
ls /dev/video0
4.Check the video format supported
v4l2-ctl --list-formats-ext
5.Display images in real time
export DISPLAY=:0.0
Enter program directory:
OV5647 currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f BA81 --width 5184 --height 1944 -d 0 --fps
#RAW10
python3 arducam_displayer.py -f Y16 --width 5184 --height 1944 -d 0 --fps
BA81 for RAW8 and Y16 for RAW10.
-width and -height indicate the width and height of the input image.
NOTE
Dropped frame?
Even if the display resolution is reduced, dropped frames may still exist due to the platform performance.
It is possible to test the actual input frames by only receiving data without displaying the image.
#RAW8
v4l2-ctl --set-fmt-video=width=5184,height=1944,pixelformat='BA81' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=5184,height=1944,pixelformat='Y16 ' --stream-mmap --stream-count=-1 -d /dev/video0
1.Install VLC media player
sudo apt-get install vlc
2.Display the image
Open VLC media player
Press Ctrl+C
【Video device name】→ select “/dev/video0“→ click 【Play】.
It may be stuck due to player performance.
Application Note
Use with Arducam USB2.0 Camera Shield
column | raw | FPS | bandwidths/MB |
2560 | 800 | 54.0 | 105.5 |
2560 | 800 | 21.0 | 41.0 |
The USB2.0 Camera Shield has a small bandwidth (around 40MB) and requires frame skipping to produce images (16.8fps original, 4.2fps after frame droppinging).
Please strictly follow the installation and operation order below, otherwise errors will occur!
1.Download File here.
2.Connect the camera module to the HAT then connect HAT to the USB Camera Shield in the case of a total power failure.
3.Power the HAT through micro USB port,then power the USB Camera Shield.
4.Run USBTest
5.Scan and select the camera device number
6.Select CfgFile
Download the CfgFile here.
7.Click 【load】- Click【open】
8.Power down the HAT then power the HAT.
9.Click【play】
Using Arducam Camarray on ROS
Please refer to this page:
