  3. Jetson Cameras
  4. Multiple cameras on the Jetson Nano
  5. Camarray – Arducam 2MP*2 Stereo Camera MIPI Module
This Arducam 2MP*2 Stereo Camera MIPI Module is a stereo camera module with two synchronized monochrome global shutter OV2311 image sensors (2×2MP). It directly connects to the MIPI CSI-2 connectors of Raspberry Pi and Jetson Nano, and runs with a V4L2 camera driver on those platforms. It offers better flexibility to be integrated into your own hardware design or run with your own algorithm on embedded systems for applications like depth sensing, 3d mapping, SLAM, etc.
What is Camarray
NOTE
Common Specs
Image sensor
Sensor ModelOV2311
Shutter TypeGlobal Shutter
Active Pixels1600*2×1300
Resolution2MP*2
Image Sensor FormatType 1/2.9″
Pixel Size3μm×3μm
Color Filter ArrayNone(Monochrome)
2311block diagam
OV2311 Block Diagram
Lens Assembly
InterchangeabilityYES
F/NO2.8
Focus TypeManual Focus
Focusing Range30cm to infinity (when focused to infinity)
Effective Focal Length(EFL)2.8 mm
Field of View(FoV)83° Horizontal
Lens MountM12 Lens
IR SensitivityNo IR filter (sensitive to IR light)
2311stero camera lens 3d
Camera Board
Camera Board Size105×24 mm
2311stereo camera board
Mechanical Drawing
Pin No.Pin NameTypeDescription
13V3Power3.3V power supply
2FSINInputFrame Sync Input
3STBOutputLED Strobe Output
4GNDGroundGround
53V3Power3.3V power supply
6SDAI/OSCCB serial interface data I/O
7SCLInputSCCB serial interface clock input
8GNDGroundGround
Connector & Cable
Connector InterfaceMIPI CSI-2 15-pin 2-lane
Ribbon Cable Length150mm (15-pin), 150mm (15-22pin)
Mating connector typeSFW15R-2STE1LF
Pin #NameDescription
1GNDGround
2CAM_D0_NMIPI Data Lane 0 Negative
3CAM_D0_PMIPI Data Lane 0 Positive
4GNDGround
5CAM_D1_NMIPI Data Lane 1 Negative
6CAM_D1_PMIPI Data Lane 1 Positive
7GNDGround
8CAM_CK_NMIPI Clock Lane Negative
9CAM_CK_PMIPI Clock Lane Positive
10GNDGround
11CAM_IO0Power Enable
12CAM_IO1LED Indicator
13CAM_SCLI2C SCL
14CAM_SDAI2C SDA
15CAM_3V33.3V Power Input
Video FormatGERY(8-bit)/Y10P(10-bit)
Output Interface2-lane MIPI serial output
Output Formats8/10-bit BW RAW
Frame rate (adjustable: 5fps~50fps)
Raspberry PiJetson Nano
RAW8(GREY)[email protected]×1300[email protected]×1300
RAW10(Y10P)[email protected]×1300[email protected]×1300
Quick Start Guide
NOTE
Same operation on Xavier NX. The only difference is the driver package.
Hardware Setup
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2.
1.Driver type
There is three drivers for Jetson:​​
  • Official IMX219 driver
  • Arducam IMX477 driver
  • Arducam V4L2 driver
NOTE
These three drivers are in conflict with each other and only one of the three options is available.​
2.Check your driver
Execute the following command and see if it responds. If there is no response, the corresponding driver is not installed.​​​
dmesg | grep imx219
Check your driver1
For example, no response, you don’t install the official IMX219 driver.
dmesg | grep imx477
Check your driver2
For example, no response, you don’t install the Arducam IMX477 driver.
dmesg | grep arducam
Check your driver3
For example, it has a response, you installed Arducam V4L2 driver. Failed means you haven’t connected Arducam IMX477 camera or the connection is wrong.
Install Arducam V4L2 driver
Please go to this page for detailed instruction.
First Use
1.Install V4L2 python module
for Python3.x:
Install V4L2 python module1
sudo python3 get-pip.py
Install V4L2 python module2
Install V4L2 python module3
 sudo pip3 install v4l2
Install V4L2 python module4
NOTE
The V4L2 of Python3.x has a known bug that requires a manual fix, and the following error occurs when you import the v4l2 module into Python3.x:
Install V4L2 python module5
You can refer to this link to fix this bug:
2.Download the demo code
Download the demo code1
Download the demo code2
3.Check whether the camera is detected
ls /dev/video0
Check whether the camera is detected1
4.Check the video format supported
v4l2-ctl --list-formats-ext
5.Display images in real time
export DISPLAY=:0.0
Enter program directory:
OV2311 currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f GREY --width 3200 --height 1300 -d 0 --fps
#RAW10
python3 arducam_displayer.py -f Y16 --width 3200 --height 1300 -d 0 --fps
​GREY for RAW8 and Y16 for RAW10.
​-width and -height indicate the width and height of the input image.
The command line will refresh the display of frames in real time.
display
NOTE
Dropped frame?
dropped frame1
dropped frame2
6.Receive data without displaying the image
#RAW8
v4l2-ctl --set-fmt-video=width=3200,height=1300,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=3200,height=1300,pixelformat='Y10P' --stream-mmap --stream-count=-1 -d /dev/video0
Receive data without displaying the image b0274 nano
7.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
Adjust exposure b0264 nano 1
v4l2-ctl -c exposure=6000
Adjust exposure b0264 nano 2
8. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
Adjust gain b0264 nano1
v4l2-ctl -c gain=200
Adjust gain b0264 nano2
9.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 40. First, open two terminals, type the following command in the first terminal:
Change frame rate b0264 1 nano
The last line shows the current frame rate in real time, and the RAW8 configuration defaults to 30fps.
v4l2-ctl -c frame_rate=40
Change frame rate b0264 2 nano
The frame rate changes to 40fps.
v4l2-ctl -l
Change frame rate b0264 3 nano
You can change the frame rate from 5fps to 50fps. If the set frame rate exceeds the maximum value, it will work according to the maximum value. The same goes for the minimum value.
IMPORTANT NOTE
For example, if the frame rate is set to 50 fps, the display only goes up to 43fps.
IMPORTANT NOTE b0264 nano 1
You can test the actual input frames by only receiving data without displaying the image.
The frame rate values here are not real-time and are calculated iteratively with historical values, changing slowly.
IMPORTANT NOTE b0264 nano 2
Open VLC media player
VLC media player
1.Display the image
Press Ctrl+C
display1
Video device name】→ select “/dev/video0“→ click 【Play】.
display2
play3
2.Adjust exposuregain, and frame rate
Press Ctrl+E, drag the sliders at “Exposure“, “Gain” and “Frame_rate” to make adjustments under the “v4l2 control” tab.
Adjust exposure gain and frame rate b0264 nano
Adjust exposure and gain ov2311
Display the Image via MPlayer
1.Install mplayer
sudo apt-get install mplayer
2.Display images
nano mplayer b0267
Or enter the following command to zoom the image.
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 520
2311 mplayer dual pic
What’s Next
  • Check the Application Note for applications like using Arducam userland MIPI camera drivers.
  • Join the discussion in our forum.
Application Note
Please refer to this page for instruction.
