This Arducam quadrascopic camera bundle incorporates four 1MP OV9281 global shutter cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT. As the upgraded version of Arducam Synched Stereo Camera HAT, the Camarray further pushes the multi-camera limits and doubles the interfacing capabilities to allow 4 synchronized MIPI camera modules to be interfaced to a single MIPI CSI-2 slot on prevailing single-board computers like Raspberry Pi, Jetson Nano, and Jetson Xavier NX.
Also, as the Camarray HAT releases, Arducam starts to support a variable baseline for stereo camera applications with some modified Arducam camera modules, such as those OV9281 ones included in this bundle. Since no shared camera board or clock-sharing soldering is required for the image sensors, you can kick off your prototyping for stereo camera applications and then decide the optimal baseline. Arducam also accepts subsequent customizations for your stereo camera applications.
What is Camarray
NOTE
Common Specs
Sensor Model | OV9281 |
Active Pixels | 1280*4×800 |
Resolution | 1MP*4 |
Pixel Size | 3μm×3μm |
Lens Assembly
Interchangeability | YES |
F/NO | 2.8 |
Focus Type | Manual Focus |
Lens Mount | M12 Lens |
Board
HAT Size | 65×56 mm |
Camera Board Size | 40×40 mm |
OV9281 Camera Board Mechanical Drawing
4 | GND | Ground | Ground |
8 | GND | Ground | Ground |
Connector & Cable
Connector Interface | MIPI CSI-2 22-pin 2-lane |
Ribbon Cable Length | 150mm (22-pin), 300mm(15-22pin), 73mm(15-22pin) |
Pin # | Name | Description |
1 | GND | Ground |
4 | GND | Ground |
7 | GND | Ground |
10 | GND | Ground |
11 | CAM_IO0 | Power Enable |
12 | CAM_IO1 | LED Indicator |
13 | CAM_SCL | I2C SCL |
14 | CAM_SDA | I2C SDA |
15 | CAM_3V3 | 3.3V Power Input |
Frame Rates | [email protected]*4 × 800(on RPi) [email protected]*4 × 800(on Jetson) |
Quick Start Guide
NOTE
Same operation on Xavier NX.The only difference is the driver package.
Hardware Setup
Check the Driver
This step is to check if you have other drivers installed. If you are sure that you don’t have other drivers installed, you can skip this step and go to install Arducam V4L2.
1.Driver type
- Official IMX219 driver
- Arducam IMX477 driver
- Arducam V4L2 driver
NOTE
2.Check your driver
dmesg | grep imx219
dmesg | grep imx477
dmesg | grep arducam
Install Arducam V4L2 Driver
First Use
1.Install V4L2 python module
for Python3.x:
sudo python3 get-pip.py
sudo pip3 install v4l2
NOTE
2.Download the demo code
3.Check whether the camera is detected
ls /dev/video0
4.Check the video format supported
v4l2-ctl --list-formats-ext
5.Display images in real time
export DISPLAY=:0.0
Enter program directory:
Quadrascopic OV9281 camera currently supports the following commands:
#RAW8
python3 arducam_displayer.py -f GREY --width 5120 --height 800 -d 0
GREY for RAW8.
-w and -h indicate the width and height of the input image.
Dropped frame?
6.Receive data without displaying the image
#RAW8
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=2560,height=800,pixelformat='Y16 ' --stream-mmap --stream-count=-1 -d /dev/video0
7.Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
8. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=12
v4l2-ctl -l
v4l2-ctl -c gain=12
9.Change frame rate
v4l2-ctl -c frame_rate=X
For example, you want to change the frame rate to 30. First, open two terminals, type the following command in the first terminal
python3 arducam_displayer.py -f GREY --width 5120 --height 800 -d 0 --fps
v4l2-ctl -c frame_rate=30
v4l2-ctl -l
Install VLC media player:
sudo apt-get install vlc
Open VLC media player:
1.Display the image
Press Ctrl+C
【Video device name】→ select “/dev/video0“→ click 【Play】.
It may be stuck due to Jetson performance and VLC media player.
2.Adjust exposure, gain, and frame rate
Press Ctrl+E, drag the sliders at “Exposure“, “Gain” and “Frame_rate” to make adjustments under the “v4l2 control” tab.
Display the Image via Mplayer
1.Install mplayer
sudo apt-get install mplayer
2.Display image
NOTE
mplayer tv:// -tv driver=v4l2:device=/dev/video0 -zoom -x 1280 -y 200
What’s Next
Application Note
Use with Arducam USB3.0 32b Camera Shield
column | raw | FPS | bandwidths/MB |
5120 | 800 | 45.0 | 175.8 |
Please strictly follow the installation and operation order below, otherwise errors will occur!
1.Download File here.
2.Connect the camera module to the HAT then connect HAT to the USB Camera Shield in the case of a total power failure.
3.Power the HAT through micro USB port,then power the USB Camera Shield.
4.Run USBTest
5.Scan and select the camera device number
6.Select CfgFile
7.Click 【load】- Click【open】
8.Power down the HAT then power the HAT.
9.Click【play】
