  3. Camera breakout board
  4. 9MP MT9N001
  5. Software Guide
Software Guide
Sensor I2C Slave Address
The MT9N001 camera I2C 8-bit slave address is fixed to 0x20. With 16bit regsiter address, and 16bit register value.
There is a ” model_id ” register (0x0000) which can help diagnose if the I2C bus is accessable and distinguish the camera models.
Camera Modelmodel_id register ( 0x0000 )
MT9N0010x2B01
Sensor Initialization
MT9N001Sample Config
3488×2616MT9N001_3488x2616_9fps.cfg
1744×1308MT9N001_1744x1308_36fps.cfg
640×480MT9N001_VGA_55fps.cfg
Manual Exposure Control
The integration (exposure) time of the MT9N001 is controlled by the fine_integration_time and coarse_integration_time registers. The limits for the fine integration time are defined by:
fine_integration_time_min ≤fine_integration_time ≤ (line_length_pck – fine_integration_time_max_margin)
The limits for the coarse integration time are defined by:
coarse_integration_time_min ≤ coarse_integration_time
The actual integration time is given by:
It is required that: coarse_integration_time < = (frame_length_lines – coarse_integration_time_max_margin)
If this limit is exceeded, the frame time will automatically be extended to (coarse_integration_time + coarse_integartion_time_max_margin) to accommodate the larger integration time.
Fine Integration Time Limits
The limits for the fine_integration_time can be found from fine_integration_time_min and fine_integration_time_max_margin.
It is necessary to change fine_correction (R0x3010) when binning is enabled or the pixel clock divider (row_speed[2:0]) is used. The corresponding fine_correction values are shown in following Table .
Fine Correction
For the fine_integration_time limits, the fine_correction constant will change with the pixel clock speed and binning mode.
Given the pixel clock is 80MHz, line_length_pck_ register (0x300c) is 0x1B5E. In order to simplify the testing purpose, we only set the coarse_integration_time_ registe(0x3012).
Exposure = 8.7ms, RegAddr = 0x3012, Value = 100
Exposure = 17.4ms, RegAddr = 0x3012, Value = 300
Exposure = 43.5ms, RegAddr = 0x3012, Value = 500
Manual Gain Control
Here we demonstrate how to change the gain through the analogue_gain_code_global_ register (0x3028 in hex, 12328 in decimal). Given the exposure register 0x3012(12306) is 10.
RegAddr = 12328 (0x3028), Value = 20
RegAddr = 12328 (0x3028), Value = 50
RegAddr = 12328 (0x3028), Value = 100
White Balance Control
The MT9N001 sensor output is RAW bayer format, each RGB channel gain is controlled by corresponding gain regsiter.
There are 5 registers related to color gain settings which can be used for control white balance.
RegisterDescription
0x0204analog_gain_code_global
0x0206analog_gain_code_greenr
0x0208analog_gain_code_red
0x020Aanalog_gain_code_blue
0x020C analog_gain_code_greenb
The global gain is used to set all color gain value at one time. The other 4 registers control GR, R, B, GB respectively.
