Sensor I2C Slave Address
The AR1820HS camera I2C 8-bit slave address is fixed to 0x6E. With 16bit regsiter address, and 16bit register value.
There is a ” chip_version_reg ” register (0x0000) which can help diagnose if the I2C bus is accessable and distinguish the camera models.
Camera Model | chip_version_reg register ( 0x0000 ) |
AR1820HS | 0x50 |
Sensor Initialization
You need a basic settings to bring up the sensor and make it working in normal streaming mode. Please contact us for the config file for the Window GUI.
Manual Exposure Control
The integration (exposure) time of the AR1820HS is controlled by the coarse_integration_time register. The limits for the coarse integration time are defined by:
coarse_integration_time_min ≤ coarse_integration_time
The actual integration time is given by:
It is required that: coarse_integration_time < = (frame_length_lines – coarse_integration_time_max_margin) Note: For AR1820HS, “coarse_integration_time_max_margin” should be 1.
If this limit is broken, the frame time will automatically be extended to (coarse_integration_time + coarse_integartion_time_max_margin) to accommodate the larger integration time. In binning mode, frame_length_lines should be set larger than coarse_integration_time by at least 3 to avoid column imbalance artifact.
Given the pixel clock is 80MHz, line_length_pck_ register (0x300c) is 0xA3FC. In order to simplify the testing purpose, we only set the coarse_integration_time_ registe(0x3012).
Exposure = 52.4ms, RegAddr = 12306 (0x3012), Value = 100
Exposure = 157.5ms, RegAddr = 12306 (0x3012), Value = 300
Exposure = 262.4ms, RegAddr = 12306 (0x3012), Value = 500
Manual Gain Control
Here we demonstrate how to change the gain through the global_gain register (0x305E in hex). Given the exposure register 0x3012(12306) is 10.
RegAddr = 0x305E, Value = 0x2001
RegAddr = 0x305E, Value = 0x2002
RegAddr = 0x305E, Value = 0x2003
White Balance Control
The AR1820HS sensor output is RAW bayer format, each RGB channel gain is controlled by corresponding gain regsiter.
There are 5 registers related to color gain settings which can be used for control white balance.
Register | Description |
0x305E | global_gain |
0x3056 | green1_gain |
0x3058 | blue_gain |
0x305A | red_gain |
0x305C | green2_gain |
The global gain is used to set all color gain value at one time. The other 4 registers control GR, B, R, GB respectively.
