This hardware guid helps for interfacing the Arducam AR1820HS camera module. There are hardware USB2 or USB3 camera shield develop boards and mipi adapter board which can well mate this camera module without designing any customize board, they can be used for fast evaluation for this camera module.
Pin Definition
2 | MDN0 | Input | Pixel Data Lane0 Negative |
3 | MDP0 | Input | Pixel Data Lane0 Positive |
4 | GND | Ground | Power ground |
5 | MDN1 | Input | Pixel Data Lane1 Negative |
6 | MDP1 | Output | Pixel Data Lane1 Positive |
7 | GND | Ground | Power ground |
8 | MCN | Input | Pixel Clock Output Form Sensor Negative |
9 | MCP | Input | Pixel Clock Output Form Sensor Positive |
10 | GND | Ground | Power ground |
11 | MDN2 | Input | Pixel Data Lane2 Negative |
12 | MDP2 | Input | Pixel Data Lane2 Positive |
14 | MDN3 | Input | Pixel Data Lane3 Negative |
15 | MDP3 | Input | Pixel Data Lane3 Positive |
16 | GND | Ground | Power ground |
17 | POWER_EN | Output | Power Enable |
18 | VCC_3.3V | POWER | 3.3v Power supply |
19 | GND | Ground | Power ground |
20 | SCL | Input | Two-Wire Serial Interface Clock |
21 | SDATA | Bi-directional | Two-Wire Serial Interface Data I/O |
22 | VCC_3.3V | POWER | 3.3v Power supply |
Mechanical Dimension
Lens Option
There are M12 or CS/C mount lenses can be used together with is camera module. This is 1/2.3″ optical format sensor, so make sure the lens optical format is bigger than 1/2.3″ or else there will be dark corner. More lens options can be found from lens product page.
Order Information
Check the camera breakout from the product page.
