Sensor I2C Slave Address
The MT9F001/MT9F002 camera I2C 8-bit slave address is fixed to 0x20. With 16bit regsiter address, and 16bit register value.
There is a ” model_id ” register (0x0000) which can help diagnose if the I2C bus is accessable and distinguish the camera models.
Camera Model | model_id register ( 0x0000 ) |
MT9F001 | 0x2E00 |
MT9F002 | 0x2E01 |
Sensor Initialization
MT9F001 | Sample Config |
4384×3288 | MT9F001_4384x3288.cfg |
2228×1254 | MT9F001_2228x1254.cfg |
1096×822 | MT9F001_1096x822.cfg |
Manual Exposure Control
The integration (exposure) time of the MT9F001/MT9F002 is controlled by the fine_integration_time and coarse_integration_time registers. The limits for the fine integration time are defined by:
fine_integration_time_min ≤fine_integration_time ≤ (line_length_pck – fine_integration_time_max_margin)
The limits for the coarse integration time are defined by:
coarse_integration_time_min ≤ coarse_integration_time
The actual integration time is given by:
It is required that: coarse_integration_time < = (frame_length_lines – coarse_integration_time_max_margin)
If this limit is exceeded, the frame time will automatically be extended to (coarse_integration_time + coarse_integartion_time_max_margin) to accommodate the larger integration time.
Fine Integration Time Limits
The limits for the fine_integration_time can be found from fine_integration_time_min and fine_integration_time_max_margin.
It is necessary to change fine_correction (R0x3010) when binning is enabled or the pixel clock divider (row_speed[2:0]) is used. The corresponding fine_correction values are shown in following Table .
Fine Correction
For the fine_integration_time limits, the fine_correction constant will change with the pixel clock speed and binning mode.
Given the pixel clock is 24MHz, line_length_pck_ register (0x300c) is 13248. In order to simplify the testing purpose, we only set the coarse_integration_time_ registe(0x3012).
Exposure = 5.5ms, RegAddr = 12306 (0x3012), Value = 10
Exposure = 16.5ms, RegAddr = 12306 (0x3012), Value = 30
Exposure = 55ms, RegAddr = 12306 (0x3012), Value = 100
Manual Gain Control
Here we demonstrate how to change the gain through the analogue_gain_code_global_ register (0x3028 in hex, 12328 in decimal). Given the exposure register 0x3012(12306) is 10.
RegAddr = 12328 (0x3028), Value = 10
RegAddr = 12328 (0x3028), Value = 50
RegAddr = 12328 (0x3028), Value = 100
White Balance Control
The MT9F001/MT9F002 sensor output is RAW bayer format, each RGB channel gain is controlled by corresponding gain regsiter.
There are 5 registers related to color gain settings which can be used for control white balance.
Register | Description |
0x0204 | analog_gain_code_global |
0x0206 | analog_gain_code_greenr |
0x0208 | analog_gain_code_red |
0x020A | analog_gain_code_blue |
0x020C | analog_gain_code_greenb |
The global gain is used to set all color gain value at one time. The other 4 registers control GR, R, B, GB respectively.
ISO Speed Equivalent Gain Settings
ISO Level | Register Address | Recommended Value | Gain Value |
ISO 100 | 0x305E | 0x1433 | 1.58 |
ISO 200 | 0x305E | 0x1832 | 3.14 |
ISO 400 | 0x305E | 0x1C32 | 6.24 |
ISO 800 | 0x305E | 0x1C64 | 12.46 |
ISO 1600 | 0x305E | 0x2C64 | 24.90 |
ISO 3200 | 0x305E | 0x4C64 | 49.76 |
