  3. Camera breakout board
  4. 13MP OV13850
  5. Software Guide
Software Guide
Sensor I2C Slave Address
The OV13850 camera I2C 8-bit slave address is fixed to 0x6C. With 16bit regsiter address, and 8bit register value.
There is “sensor_model_id ” registers (0x300A/0x300B) which can help diagnose if the I2C bus is accessable and distinguish the camera models.
SENSOR_MODEL_ID RegisterValue
0x300A0xD8
0x300B0x50
Sensor Initialization
You need a basic settings to bring up the sensor and make it working in normal streaming mode. Please the config file for the Window GUI.
ResolutionSample Config
RAWOV13850_mipi_4L_raw10_4224x3136_3fps.cfg
Manual Exposure Control
The OV13850 supports two different exposure modes, one is standard exposure mode, and the other is HDR mode. In HDR mode, the exposure is still controlled by a rolling shutter. However, the frame data is separated into “long exposure” and “short exposure” in every two rows. The sequence of MIPI output in HDR mode is similar to normal mode.
White Balance Control
The OV13850 sensor output is RAW bayer format, each RGB channel gain is controlled by corresponding gain regsiter. There are 6 registers related to color gain settings which can be used for manually controlling white balance.
Was this article helpful to you? Yes 1 No 1
