  3. Camera breakout board
  4. 13MP OV13850
  5. Hardware Guide
Hardware Guide
This hardware guid helps for interfacing the Arducam OV13850 camera module. There are hardware USB2 or USB3 camera shield develop boards and mipi adapter board which can well mate this camera module without designing any customize board, they can be used for fast evaluation for this camera module.
Pin Definition
The camera module using Molex 0522711579 or similar 15pin 1mm pitch FPC connector.
1 GND Ground Power ground
2 MDN0 Input Pixel Data Lane0 Negative
3 MDP0 Input Pixel Data Lane0 Positive
4 GND Ground Power ground
5 MDN1 Input Pixel Data Lane1 Negative
6 MDP1 Input Pixel Data Lane1 Positive
7 GND Ground Power ground
8 MCN Input Pixel Clock Output Form Sensor Negative
9 MCP Input Pixel Clock Output Form Sensor Positive
10 GND Ground Power ground
11 POWER_EN Output Power Enable
12 LED-EN Input Led Enable
13 SCL Input Two-Wire Serial Interface Clock
14 SDATA Bi-directional Two-Wire Serial Interface Data I/O
15 VCC_3.3V POWER 3.3v Power supply
Mechanical Dimension
Order Information
Check the camera breakout from the product page.
