Sensor I2C Slave Address
The OV7675 camera I2C 8-bit slave address is fixed to 0x42. With 8bit regsiter address, and 8bit register value.
There is two product ID register (0x0A and 0x0B) which can help diagnose if the I2C bus is accessable and determine the camera models.
Product ID Register | Value |
0x0A | 0x76 |
0x0B | 0x73 |
Sensor Initialization
Camera | Sample Config |
OV7675_640*480 | OV7675_VGA_8bit.cfg |
