  4. 4. Use on Jetson Nano
  5. 4.4 Play the Video Feed with VLC Media Player
Jetson VLC settings
1. Open VLC with command line vlc , or click the icon to launch.
2. Hit the (Play) button to call the open media window.
3. In Capture Device >> Device Selection >> Video device name, select the camera video node.
4. Hit Advanced Options... button
5. In Advanced Options window >> Video input chroma format, type UYUV.
6. Type in the width and height, for example, 1920 and 1080.
Note​​
VLC might not be able to support video width or height larger than 4000.
7. Hit OK to save the settings and see the video feed.​​​​​​​​​​​​​​
8. Open Adjustments and Effects >> v4l2 controls property page, you can adjust the camera control parameters manually.
Jetson VLC ctl
Was this article helpful to you? Yes No 1
