  4. 3. Use on Raspberry Pi
  5. 3.9 Python example
3.9 Python example
In order to meet the special needs of customers, arducam has released some test demos for special scenarios.
  • IRCUT control
The function of the this demo is to control the IR CUT. Capture and preview the video streaming. The following is the soruce code.​​​ When press ‘q’ button, it will switch to the max resolution and save one frame to the local path.
import numpy as np
import cv2
import v4l2
import time
import subprocess
cap = cv2.VideoCapture(0)
while(True):
    # Capture frame-by-frame
    subprocess.call(['v4l2-ctl -d /dev/video0 -c ircut=0'],shell=True)
    time.sleep(0.1)
    ret, frame = cap.read()
    cv2.imshow('Arducam ar1335 ircut=0',frame)
    subprocess.call(['v4l2-ctl -d /dev/video0 -c ircut=1'],shell=True)
    time.sleep(0.1)
    ret, frame2 = cap.read()
    cv2.imshow('Arducam ar1335 ircut=1',frame2)
    if cv2.waitKey(1) & 0xFF == ord('q'):
        print("Saving image...")
        cap.set(3,4160)  #set width
        cap.set(4,3120)  #set height
        time.sleep(0.1)
        time.sleep(0.1)
        print("ircut=1")
        cap.grab()
        cap.grab()
        cap.grab()
        cv2.imwrite("image_ircut_1.jpg",frame)
        time.sleep(0.1)
        print("ircut = 0")
        cap.grab()
        cap.grab()
        cap.grab()
        cap.grab()
        cap.grab()
        ret,frame2 = cap.read()
        cv2.imwrite("image_ircut_0.jpg",frame2)
        break
# When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
ar1335 ircut test
