  4. 3. Use on Raspberry Pi
  5. 3.2 V4L2 OBISP Driver Installation & Uninstallation
1. Download V4L2 OBISP driver for OBISP MIPI camera
1
2. Extract the Archive files
tar zxvf Release.tar.gz
2
3. Enter the extracted folder
cd Release/
4. Install V4L2 OBISP driver
./install_driver.sh
obisp raspberry pi install driver and reboot
5. Reboot the device
Press y, and then hit Enter to reboot.
6. Uninstall the driver
Note that the OBISPcamera driver will occupy CSI hardware resources. After installation, you will not be able to use the raspistill tool. There are two ways to uninstall the driver.
cd Release/
./uninstall_driver.sh
Method 2: Modify the configuration file
1.Type the following command:
sudo nano /boot/config.txt
2.Press【PageDown】several times or scroll your mouse wheel down to check if there is “dtoverlay=arducam”.
dtoverlayarducam”
Modify “dtoverlay=arducam” as “#dtoverlay=arducam” to uninstall the V4L2 driver. Press 【Ctrl+X】【Y】,【Enter】to save the change and exit.
NOTE
You have to reboot your Pi to make it effect.
Driver Uninstallation
By the way, there are two ways to uninstall the Arducam V4L2 OBISP driver.
Enter the catalog
cd Release/
Excuting an order
It will take effect after rebooting.
Excuting an order
Press PgDn to find dtoverlay=arducam at the end.
Modify it to #dtoverlay=arducam, press Ctrl+X, y, Enter to save and exit.
