1. Introduction
Arducam 2MP Global shutter OV2311 camera module is designed for Raspberry Pi boards, and it can be connected to RPi’s CSI-2 camera interface without additional hardware. The camera driver is using on the Arducam OBISP camera driver although this OV2311 module doesn’t support hardware ISP functionalities. The OBISP camera driver is based on the V4L2 driver framework. It is software friendly driver that most of the camera applications can access to the camera. The most important, using C/C++, OpenCV to access the camera is fairly straightforward.
2. Specs
Note: This module does not support On-Board ISP, and does not support automatic adjustment of exposure and gain. By the way, you can choose the module that suits you according to your needs for the lens. The following table is for your reference.
SKU | Lens Thread | Lens Field of View(FoV) | IR Sensitivity |
B0220 | M9 x 0.25P | 55°(H) | Without IR Filter, IR sensitive |
B0221 | M12 x 0.5P | 83°(H) | Without IR Filter, IR sensitive |
Image sensor
Sensor Model | OV2311 |
Active Pixels | 1600×1300 |
Resolution | 2MP |
Image Sensor Format | Type 1/2.9″ |
Pixel Size | 3μm×3μm |
3. Hardware
Note: If you have the signal OV2311 camera board, you can not install the V4L2 OBISP driver without a Pivariety board like the figure under the camera board. You can follow the DOC to install the MIPI_Camera driver and access the camera.
4. Software
4.1. V4L2 OBISP Driver Installation
Please refer to here!
4.2. First Use
4.2.1.Check whether the camera is detected
ls /dev/video0
4.2.2. Check the video format supported
v4l2-ctl --list-formats-ext
4.2.3. Preview the camera feed in real time
#RAW8
arducamstill -t 0 -pixfmt GREY -w 1600 -h 1300
#RAW10
arducamstill -t 0 -pixfmt Y10P -w 1600 -h 1300
The last line shows the frame rate in real-time.
GREY for RAW8 and Y10P for RAW10.
Press Ctrl+C to exit the preview.
Advanced Commands
#View v4l2 command parameters
v4l2-ctl -l
#Adjust exposure
v4l2-ctl -c exposure=100
#Adjust gain
v4l2-ctl -c gain=14
4.2.4. Receive data without displaying the image
#RAW8
v4l2-ctl --set-fmt-video=width=1600,height=1300,pixelformat='GREY' --stream-mmap --stream-count=-1 -d /dev/video0
#RAW10
v4l2-ctl --set-fmt-video=width=1600,height=1300,pixelformat='Y10P' --stream-mmap --stream-count=-1 -d /dev/video0
4.2.5. Adjust exposure
#Adjust exposure:
v4l2-ctl -c exposure=1000
v4l2-ctl -l
v4l2-ctl -c exposure=4000
Increasing the exposure time results in a brighter image and a lower frame rate.
4.2.6. Adjust gain
#Adjust gain:
v4l2-ctl -c gain=255
v4l2-ctl -l
Increasing the gain results in a brighter image and no change to the frame rate.
4.3. Display Images via VLC Media Player
Please refer to the steps in this chapter!
4.4. Display Images via Mplayer
4.5. External Trigger Mode
