  4. 2. Supported Camera Modules
  5. 2.1 13MP AR1335
2.1 13MP AR1335
Image Sensor13MP AR1335
Maximum Resolution4160×3120
Pixel Size1.1um
Optical Format1/3″
Lens MountM12 default, optional CS mount
Stock Lens FOVhorizontal 90 degrees
Output FormatYUV422, RGB888
Output Interface2-Lane MIPI CSI-2
Max data rate1.2Gbps/lane
Supported Resolution&Frame rateUYUV:
4160×[email protected],
3264×[email protected] 10fps
3840×[email protected]
2560×[email protected]
1920×[email protected]
1600×[email protected]
1280×[email protected]
640×[email protected]
320×[email protected]
RGB3:
Support ISP FunctionsAWB, AE, Flip, Mirror, Denoise, Gamma, Sharpness, Saturation, Contrast Digital Zoom, Digital Pan/Tilt, Speical Effects etc.
Night Vision AbilityOptional with additional Motorized IR-Cut filter
Sensitivity4.7k e/lux-sec
SNRmax37dB
Dynamic Range69dB
Power Consumption270mW
Temperature Range-10 ~ 70 degrees Celcius
Camera DriverV4L2 Compliant driver for Raspberry pi and Jetson Nano
Board Size38x38mm
Pinout
See Raspberry pi standard 15pin connector pinout
Applications:
  • Cellular phones
  • Digital still cameras
  • PC cameras
  • IoT cameras
Mechanical Drawing​​
AR1335 OBISP dimension
Available off-the-shelf products
Currently, the 13MP AR1335 camera module are available in two models: one with standard M12 lens mount, the other with a switchable/mechanical IR-cut filter.
